Every instrument needs a web server built in. This is just an amazing and powerful feature that they would change the landscape by including web control/monitoring in their entire product line.
Please no. If you want web server, you can use SBC computer for that
Maybe you totally underestimate the power of instrument webservers.
Remote control and the many ways it can be used might surprise you.
One of the first SDS2104X-P we sold within days identified an issue a company was having at a remote site with the scope set correctly to trigger and Single shot on this event and monitored remotely.
This issue had bugged then for 18+ months.
Further, with the connectivity path set correctly the screenshot of the incident was sent and saved locally for them to analyze and time stamped !
WiFi dongle support for the SDS800X HD Series.
omg, only as external option. It produce a lot of interference. This is not good for measurement equipment.
This is current supported for 4ch X-E DSO range as an option......these are 200 MHz max DSO's operating well below any 2.4 GHz WiFi.
TBH we have more issues with the horribly noisy SMPS from LED lighting or POS wallwarts than anything that 2.4 GHz WiFi can produce.
Sorry but you're
