Gave up on the wireless and just tried to link things up with direct Ethernet port with the MAC, couldn't get the Siglent equipment (SDS2102X+ and SDG2042X) to work. The KS34465A linked up right away and worked fine. Then tried using a Ethernet switch between the MAC and Siglent, same result KS worked but neither Siglent would work. So then tried this with the Raspberry P i3+ running Raspbian, tried direct Ethernet port on RPi and KS hooked up right away, neither Siglent would. Also tried with Ethernet switch to RPi, same results KS worked, Siglent's didn't.
This is what I recall from last year, couldn't get the Siglents to work directly with Ethernet direct to MAC, or with direct connect to cable modem/router and with MAC direct to router, but did work with MAC wireless connection to cable modem/router.
I'm sure this is something to do with Siglent LAN setup, but not sure what this would be.
They are setup with Automatic DHCP OFF.
DSO IP is 10.11.13.220, AWG IP is 10.11.9.230
Looks like I may to bring the cable modem/Router back from the other room and do some more troubleshooting
Wish I knew more about this networking stuff, but we always had the IT handle this when I was working, and never needed to get involved until after I retired.
Any suggestions/help is greatly appreciated.
Best,
