First thing I did was check the version had changed, however I'll update again later just to make sure.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
I don't think the Save Print filetype's have changed, still just
waveform or
picture.
Edit. Updating the firmware again, reformatting the memory stick, reboots, self-calibrations = no difference as expected.
Pressing
STOP while
Long Memory is enabled doesn't freeze the displayed waveform, it clears the screen and waits/acquires 1 new trigger, makes it near impossible to capture slower/infrequent events at the higher sampling rate and record length of Long Memory.
Long Memory gets confused on changes of timebase speed, and a forced trigger doesn't clear it, FWs .12, .16, P18 all the same screens:
https://www.eevblog.com/forum/testgear/siglent-cml-firmware/msg1091615/#msg1091615No persistence on 100ns with 2 channels in use. No persistence on 100ns and 50ns with 1 channel in use.
No persistence on the expanded waveforms in Zoom/Delay mode.
ETS is slow and unstable, but that goes with saying!
