As I've told SMB784, I advise all to:
1st option -
Instead of the official OS install, install janekivi full OS file. It's exactly the same thing with the pwds already changed.
2nd option -
After installing the official OS, when you install janekivi patch, do it only with the rootfs file (and the script .txt, of course).
Less operations, less risk!
Regarding the advice of CustomEngineerer about the login problem: thinking of it, it was totally right and not an insult, it could have been a problem with the client SMB784 was using to connect to the scope. Although SMB784 was able to see the correct prompt, there was no assurance that
what he writes in the console was correctly/transparently being sent to the scope.
A solution could have been to change the client (I usually use Putty) or investigate what was introducing garbage in the connection.
Or, in the extreme, use (in his case) the RPi as a gateway to telnet to the scope...
Glad it is solved! Now, time for upgrade.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
