Sorry, I post the unpack script few min ago and I've deleted it. I have figured out the ADS file format shared by SDG2000x, SSA3000x etc.
There some other reasons I have not released the code
1) the "upgrade" mechanism for SDG2042x to 120MHz is still working. O0
2) if siglent fixes the bug. A license can be generated to keep the 120MHz ability. I have made a license generator.
3) if the telnet/ssh connect is blocked someday and a white list is embedded, a unofficial ADS file can be made to unblock it.
4) I am a little bit worried about the consequences.
5) I expect that siglent keeps using this format in the future.
So, if you are the owner of SDG2042x , do not be worried about losing the 120MHz.
If you want to do some research on the options of something like SSA3000x or so, I can send the ELF file to you.
For the 3DES, they implemented the wrong way, here is the algorithm they use.
