Wondering if anyone else has seen this remote logging issue using EasyDMM s/w?
When collecting remote measurements using EasyDMM (USB or LAN) I've found that Manual sample rate settings (tried fast to very slow) return duplicate readings about every 5-15 readings. The time increment increases normally but the reading is idential to the previous reading. When I go to Auto mode, which samples about 5sa/sec, the problem seems to disappear.
I've attached a pix what a clean sine wave input to the DMM produces when using Manual sampling in EasyDMM.
Anyone else seen this?
Thanks - Scott
