I am considering to buy either SDS1104X-U or SDS1202X-E as my first oscilloscope. I am asking your opinion which scope I should purchase.
Currently, I have no intentions to operate the scope at high frequencies of over 100MHz+, or using more than two channels, so the decision is tough. SDS1202X-E has somewhat better and less noisy frontend than Siglent's budget 4 channel scope, and it has also better FFT resolution, but I do not know if they are worth of 2 extra channels.
I definitely need I2C and UART decoders and preferably triggers as well (my interest is to debug noisy and long I2C transmission lines and various simple frequency-output sensors), so these Siglent scopes are the ones I consider the best for me. Have you regretted of buying a 2 channel scope over a 4 channel one? Or vice versa, do you think a 200 MHz scope with good noise and FFT features is better than a worse 4 channel scope?
