Which one would you prefer?
The Hantek DSO2C10 for $130.
This is the post I was referencing. The last 2 plots are the correct analog to what I was doing
The width of the FFT bins is 1/(n*dT). The maximum frequency is 1/(2*dT). The 10k buffer works because it's aliased. As I reduce the sample rate the sidelobes spread out as T=n*dT increases.
A proper waterfall display has been on my "To Do" list for quite a while. Time for me to grind my way through the math and replicate the Instek SA software so other OEMs can include the feature in DSOs and SDRs.
I was comparing to all the DSOs I had handy. And a 1GHz LeCroy is probably not a fair comparison nor was it handy. The DS1102E was my first DSO.
The Hanmatek appears to be the Owon minus the internal SMPS. The DOS1104 has 5 mV/div instead of the 20 mV/div of the DOS1102. I ordered a DOS1104 from Aliexpress for $206 for the sake of the greater sensitivity.
I bought a Hantek 3 in 1 which was very poor. Replaced it with an Owon HDS272S which is a proper scope with limited controls. I had always assumed that Hanmatek was a step down from Hantek, so I was quite surprised when I measured the risetime.
Have Fun!
Reg
