Thanks! Here I am looking in the manual and the answer is right on the faceplate. o:
While 1000v isolation would be great for me, I don't expect bench meters to be like that. I do want to know the design limits of a device so I don't brick it. I can still use this sort of meter for tube work, and 500 volts covers almost everything except for the power tubes. At the very least, one can measure the voltage on both sides of the resistor and subtract...
