Author Topic: DIY Oscilloscope kits - any recommendations?  (Read 4557 times)
Offline SolderSuckerTopic starter
« on: September 19, 2017, 03:07:50 pm »
As I'm currently thinking of buying some form of digital 'scope, and bearing in mind that I really enjoy making up electronic kits, I'm thinking that buying a 'scope kit would be a good idea. But are there any good quality ones out there? Must also include a case/enclosure.
Must also be at least 20 MHz, preferably higher. Single or dual trace, I'm not worried.
Offline alanb
Re: DIY Oscilloscope kits - any recommendations?
« Reply #1 on: September 19, 2017, 03:49:18 pm »
Not sure is any of these kits are any use if you need an oscilloscope however you may get some fun out of building the kit. Have a look at Jullian Ilett's video
https://youtu.be/-nPiMGb3Qb8
I think there are a few other examples of this kit being built, unfortunately I cant remember who did them.
Online Fungus
« Reply #2 on: September 19, 2017, 03:51:30 pm »
The only kit I know is this one: https://www.ebay.com/sch/i.html?_nkw=DSO138
Nobody would say it's a good oscilloscope though.
Nope.
Offline alanb
« Reply #3 on: September 19, 2017, 03:54:00 pm »
Another video about the construction of the cheap kit. This one is by John Orbiter
https://youtu.be/GsRVUcKShSk
Offline WhichEnt2
  • Country: ru
« Reply #4 on: September 19, 2017, 04:32:47 pm »
Most diy kit scopes from jyetech don't have a bandwidth above 200 kHz.
I've seen a couple of projects which can be close to your 20 MHz requirements but they are being arranged in somewhat like group-buy way and after a few runs they are closed.
Short pieces, high value, small period, huge amount, long delay.
Offline daybyter
« Reply #5 on: September 19, 2017, 04:33:27 pm »
Offline tooki
« Reply #6 on: September 19, 2017, 04:43:54 pm »
I built a DSO138 kit (the one shown in the two videos above), and while it's fun enough to assemble, it's kind of a pain in the ass to use.
The new model, the DSO Shell (DSO150) not only has a proper enclosure, but has apparently much improved controls, which are one of the big shortcomings of the DSO138.
See http://www.jyetech.com/Products/LcdScope/e150.php
« Reply #7 on: September 19, 2017, 04:48:04 pm »
Thanks for all of the suggestions so far. :)
I do wish that those who produce such kits wouldn't pre-mount the surface mounted parts - while I can appreciate that some people don't like soldering them on, some of us are fine with it.
« Last Edit: September 19, 2017, 04:49:58 pm by SolderSucker »
Online Fungus
« Reply #8 on: September 19, 2017, 05:08:28 pm »
Feel free to take them off and put them back again.  :popcorn:
Offline tooki
« Reply #9 on: September 19, 2017, 05:41:02 pm »
Look carefully: JYE Tech offers its kits both with and without the SMD components soldered, so if you buy a genuine kit, you have the choice.
The counterfeit ones on eBay, Aliexpress, and Banggood, however, are invariably the version with the SMD pre-soldered.
« Reply #10 on: September 19, 2017, 05:45:28 pm »
Duly noted, thanks for pointing that out.
