I tried an experiment with my SDL1020X-E (upgraded to be a 1030X).
I loaded it down to 4A (120W at 30V) and monitored the unit for sound using my Audio Control SA3050A Audio 1/3 Octave RTA (has 30 bands from 25Hz to 20KHz), this has a sensitivity of ~50dBm using its OEM calibrated microphone. It did not register any noise from the SDL under load and when pressing buttons, of course the noise could have been higher than 20KHz, I used to be able to hear to about 24KHz when I was younger, now it is only about 12KHz, that and the ringing in my ears....
The only noise present were the key beeps (which I personally like to have turned on, usually)
