Hello again,
Thanks everyone for their opinions and the discussion.
I think I will go for UT61E, given its specs.
I have just another question, if you could answer, id appreciate it.
I own a Vichy VC99. I recently discovered that there is a little bit of room for LED backlight installation.
I also noticed that there the battery is 3V, and its easily attachable to the PCB.
So what I am thinking is simply getting 2 LEDs and plugging them in parallel.
Would I use any kind of drive circuit if I want to use a high-power LED? Can I simply hook up a 1W led to the 3V battery (by attaching aswitch of some sort)
I would assume with normal LED, it should work fine, I'm wondering if I can use a high-power LED in its simplest form. Would too much current draw burn the circuity of the PCB, as the same source is also powering the PCB?
I know its a bit of a rookie question, but better to be safe then sorry I think.
Thanks in advance.
