Hi guys, I have the almost mandatory DS1054Z which covers many of my needs, but I have started to consider purchasing an MSO5000 for better performance and a function generator(which I don't have in my "lab").
I would probaby buy the MSO5074(to get four probes) and then hack it to all options, which will set me back around 1100 EUR. Thats completely doable, as far as I can tell. Then I'll sell my DS1054Z, which can bring in just short of 300 EUR, bringing my total expenses to 800 EUR for a nice-spec scope and a function generator. I know the function generator isn't up to par with a separate unit(its only 5Vpp), but its most likely enough for me(I need line-level audio signals and perhaps some PWM stuff for SMPS control).
What are your opinions of the MSO5000 series? I am especially interested in the front-end overdrive recovery, which is apparently much better than competing scopes and allows you to measure low-voltage signals superimposed onto high-voltage signals(e.g. drain-source on voltage on a switching node). The EEVBlog review sort of knocks it for firmware bugs, but I assume that most of those are fixed now?
