Author Topic: Hacking old HP spectrum Analyzers  (Read 20167 times)
Online MarkL
Re: Hacking old HP spectrum Analyzers
« Reply #25 on: March 21, 2019, 07:30:43 pm »
Now I have to figure out what this option actually does...
You might find this enlightening: "Time-Gated Spectrum Analysis: New Measurement Fundamentals" :
  http://literature.cdn.keysight.com/litweb/pdf/5952-3685.pdf
Everything you ever wanted to know about option 105.
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #26 on: March 21, 2019, 08:57:12 pm »
Thanks!
I found that, too, shortly after posting the question.
But I have a new question: obviously my unit lacks the GATE INPUT and OUTPUT connectors on the rear. Do you know if I can retrofit them? Where would I need to hook them up? I saw some empty connectors on the inside...
And where could I source appropriate connectors and cables?
Not that I need this option, but would be nice to do the upgrade properly...
Regards,
Vitor
Online MarkL
« Reply #27 on: March 21, 2019, 10:07:37 pm »
Thanks!
Regards,
Vitor
Most (but not all) in this series have the GATE INPUT and GATE OUTPUT built onto the processor board.  J500 is GATE OUTPUT and J501 is GATE INPUT.  See photo for the location on the bottom of the unit.  If it's not marked, J501 is the one closer to the edge.
The two cables are part numbers 08591-60077 and 08591-60076 if you want to search around for them.  But they are just ordinary 50-ohm SMB right angle to BNC jumper cables that you can easily make yourself.
Offline Bicurico
  • Country: pt
« Reply #28 on: March 21, 2019, 10:55:15 pm »
Thanks! With your part numbers I found the installation manual: http://literature.cdn.keysight.com/litweb/pdf/5967-8554.pdf
Offline Bicurico
  • Country: pt
« Reply #29 on: March 21, 2019, 11:12:31 pm »
Here how to enable/disable the 001 option (75 Ohm): "Opt 001 75 W Input (HP 8590L only)"
Enabled = 75 Ohm RF Input
Disabled= 50 Ohm RF Input
I have not tested this (is not even available for my model), but got these from the Keysight forum. This is useful in case the RAM contents are lost. If you have a 75 Ohm device, it would default to 50 Ohm and CAL would fail.
Enable 75 Ohm:
Preset
Frequency -2001 Hz
Amplitude, More 1 of 2
Input Z 75-ohm
Amplitude, Scale Log Lin (Log), More 1 of 2 Amptd Units dBmV
Amplitude, Scale Log Lin (Lin), More 1 of 2 Amptd Units dBmV
Cal, More 1 of 4, More 2 of 4
Service Cal, Stor Pwr On Units
Disable 75 Ohm - enable default 50 Ohm:
Preset
Frequency, -2001 Hz
Amplitude, More 1 of 2, Input Z 50-ohm
Cal, More 1 of 4, More 2 of 4, Service Cal, Stor Pwr On Units
Regards,
Vitor
Offline Bicurico
  • Country: pt
« Reply #30 on: March 21, 2019, 11:14:26 pm »
I am now wondering if there are more "secret" key codes to activate other options...
What about firmware upgrades?
Online MarkL
« Reply #31 on: March 22, 2019, 12:15:14 am »
I'm not aware of any other hidden options like the gated analysis.
The firmware is all in EPROM.  Here's a document describing the various versions:
  http://literature.cdn.keysight.com/litweb/pdf/08590-90324.pdf
KO4BB has a good collection up to version L:
  http://www.ko4bb.com/getsimple/index.php?id=download&file=HP_Agilent/HP_859xE_859xE_series_SA_firmware_EPROM.zip
They don't have the latest version M with the Agilent logo (aawww...).
Offline Bicurico
  • Country: pt
« Reply #32 on: March 23, 2019, 10:31:31 pm »
I am looking at the USER MEMORY dump I made using the USTATE? command.
I had some strange DLP's installed, which I unfortunately erased while trying to use the USTATE command to upload a backup.
Warning: using USTATE without the "?" is used to upload a user memory backup. If that fails (and it will fail in 99.9% of cases), you end up with a fresh deleted user memory.
Anyway, I think I had some calibration/support/service personality installed on my device and there are interesting passages in the DLP:
Here one program to check some fault:
IP;CF-2001HZ;CAL FREQ;
MOV S_TAT,STB?;
  IF S_TAT,GT,0,THEN
    CLRDSP;BLANK TRA;GRAT OFF;ANNOT OFF;MENU 0;
    PU;PA,100,100;TEXT%CAL. FREQ. **FAILED**%;
    PU;PA,100,90 ;TEXT%---------------------%;
    PU;PA,100,60 ;TEXT%PRESS [PRESET]       %;
    PU;PA,100,50 ;TEXT%PRESS [FREQ],-2001Hz,%;
    PU;PA,100,40 ;TEXT%& [CAL],CAL FREQ.    %;
    PU;PA,100,30 ;TEXT%...TO ISOLATE PROBLEM%;
    ABORT;
  ENDIF;
CAL AMP;
MOV S_TAT,STB?;
  IF S_TAT,GT,0,THEN
    PU;PA,100,80;TEXT%CAL. AMP. **FAILED**%;
    PU;PA,100,70;TEXT%--------------------%;
    PU;PA,100,50 ;TEXT%PRESS [PRESET]       %;
    PU;PA,100,40 ;TEXT%PRESS [FREQ],-2001Hz,%;
    PU;PA,100,30 ;TEXT%& [CAL],CAL AMP.     %;
    PU;PA,100,20 ;TEXT%...TO ISOLATE PROBLEM%;
    ABORT;
  ENDIF;
CAL STORE;
Notice the "IP;CF-2001HZ;CAL FREQ;" this must be the key sequence to do all sort of weird stuff...
Take a look at this thread, too: https://www.eevblog.com/forum/testgear/hp8590e-series-option-103-driver/
I will continue to write about hacking the device here...
Regards,
Vitor
Offline Bicurico
  • Country: pt
« Reply #33 on: March 23, 2019, 11:38:58 pm »
I *think* I managed to rebuild the installed software, which I lost.
KEYDEF 101,W_ARM,%Warm Up |859x%;
KEYDEF 102,C_PU,%CPU Pre-|Test%;
KEYDEF 103,S_CAP,%Super   |Cap%;
KEYDEF 104,M_EAS,%Measure |Test%;
KEYDEF 105,I_NIT,%Init    |Test%;
KEYDEF 106,R_EVDATE,%DLP     |Revision%;
FUNCDEF S_TIME,@
I_NIT;
S_CAP;
M_EAS;
MENU 1;
FUNCDEF M_EAS,@
C_HECK;
S_TIME;
E_LAPSE;
C_AL;
D_ONE;
MENU 1;
FUNCDEF C_HECK,@
MOV C_LOCK,HAVE CNT;
IF C_LOCK,GT,0,THEN;
  MOV S_TAT,STB?;
    IF S_TAT,GT,0,THEN
      PU;PA,50,190;TEXT% PRE WARM-UP CAL. CHECK%;
      PU;PA,50,180;TEXT% ----------------------%;
      PU;PA,100,110;TEXT% --------------------- %;
      PU;PA,100,100;TEXT%|CAL. FREQ. **FAILED**|%;
      PU;PA,100,90 ;TEXT% ---------------------%;
      PU;PA,50,140;TEXT%$$$$ WARM-UP WAS NOT DONE $$$$%;
      ABORT;
    ENDIF;
  CAL AMP;
  MOV S_TAT,STB?;
    IF S_TAT,GT,0,THEN
      PU;PA,100,90;TEXT%  -------------------- %;
      PU;PA,100,80;TEXT%| CAL. AMP. **FAILED**|%;
      PU;PA,100,70;TEXT%  --------------------%;
      PU;PA,100,50;TEXT%PRESS [PRESET]       %;
      PU;PA,100,40;TEXT%PRESS [FREQ],-2001Hz,%;
      PU;PA,100,30;TEXT%& [CAL],CAL AMP.     %;
      PU;PA,100,20;TEXT%...TO ISOLATE PROBLEM%;
      ABORT;
    ENDIF;
  CAL STORE;
ENDIF;
FUNCDEF C_AL,@
MOV S_TAT,STB?;
  IF S_TAT,GT,0,THEN
    ABORT;
  ENDIF;
CAL AMP;
MOV S_TAT,STB?;
  IF S_TAT,GT,0,THEN
    ABORT;
  ENDIF;
CAL STORE;
FUNCDEF E_LAPSE,@
MENU 0;
REPEAT
  MOV T_REG,TIMEDATE;
  MOV T_IME,T_REG;
  DIV T_IME,T_IME,10000000000;
  MOV Y_EAR,T_IME;
  INT Y_EAR,Y_EAR;
  MOV T_IME,T_REG;
  DIV T_IME,T_IME,100000000;
  MOV M_ONTHS,T_IME;
  MPY Y_EAR,Y_EAR,100;
  SUB M_ONTHS,M_ONTHS,Y_EAR;
  INT M_ONTHS,M_ONTHS;
  MOV T_IME,T_REG;
  DIV T_IME,T_IME,1000000;
  MOV D_AYS,T_IME;
  MPY Y_EAR,Y_EAR,100
  MPY M_ONTHS,M_ONTHS,100;
  ADD T_EMP,M_ONTHS,Y_EAR;
  SUB D_AYS,D_AYS,T_EMP;
  INT D_AYS,D_AYS;
  MOV T_IME,T_REG;
  DIV T_IME,T_IME,10000;
  MOV H_OUR,T_IME;
  MPY Y_EAR,Y_EAR,100
  MPY D_AYS,D_AYS,100;
  ADD T_EMP,D_AYS,T_EMP;
  SUB H_OUR,H_OUR,T_EMP;
  INT H_OUR,H_OUR;
  MOV H_REG,H_OUR;
  MOV T_IME,T_REG;
  DIV T_IME,T_IME,100;
  MOV M_IN,T_IME;
  MPY Y_EAR,Y_EAR,100
  MPY H_REG,H_REG,100;
  ADD T_EMP,H_REG,T_EMP;
  SUB M_IN,M_IN,T_EMP;
  INT M_IN,M_IN;
  MOV T_IME,T_REG;
  MOV S_EC,T_IME;
  MPY Y_EAR,Y_EAR,100
  MPY M_IN,M_IN,100;
  ADD T_EMP,M_IN,T_EMP;
  SUB S_EC,S_EC,T_EMP;
  INT S_EC,S_EC;
    IF I_NDEX,EQ,0 THEN
      MOV S_REG,S_EC;
      PU;PA,95,40;TEXT%ELAPSE=   %;PA,175,40;TEXT% MINUTES%;
      PU;PA,135,30;TEXT%&   %;PA,175,30;TEXT% SECONDS%;
      MOV S_aveDa,DA;
      PU;PA,158,40;
      DSPLY,M_CNT,2.0;
      PU;PA,158,30;
      DSPLY,S_CNT,2.0;
      ADD I_NDEX,I_NDEX,1;
    ENDIF;
    IF S_REG,NE,S_EC THEN
      ADD S_CNT,S_CNT,1;
      MOV S_REG,S_EC;
    ENDIF;
    IF S_CNT,EQ,60,THEN
      SUB S_CNT,S_CNT,60;
      ADD M_CNT,M_CNT,1;
    ENDIF;
  MOV L_astDa,DA;
  MOV DA,S_aveDa;
  PU;PA,158,40;
  DSPLY,M_CNT,2.0;
  PU;PA,158,30;
  DSPLY,S_CNT,2.0;
  MOV DA,L_astDa;
{ds_sync()};
UNTIL (M_CNT >= W_RMUP);
CLRDSP;
FUNCDEF I_NIT,@
IP;CF-2001HZ;CAL INIT;CAL FETCH;CAL STORE;TS;
BAUDRATE9600;KSP18;PLOTADRS5;
PSTATE0;PREFX%%;VARDEF _PRT;VARDEF _CLR;PRNTADRS1;PLT0;
CRTVPOS20;CRTHPOS8;KS<0;IP;
POWERON IP;
IP;CF-2001HZ;INZ 50;AUNITS DBM;LN;AUNITS V;LG;CAL UNITS;TS;
CF-2001HZ;CAL TIMEBASE 128;
CF-2001HZ;CALATNDATA 0,0,0,0,0,
PREAMPG 0;
AMPCOR 30GHZ, 0DB;AMPCOR OFF;
GRAT OFF;ANNOT OFF;BLANK TRA;MENU 0;
PU;PA 100,115;TEXT%  INITIALIZATION COMPLETE       %;
PU;PA 100,105;TEXT%============================%;
PU;PA 100,95;TEXT%- DEFAULT CAL DATA LOADED       %;
PU;PA 100,85;TEXT%- TIMEBASE DEFAULTED TO 128      %;
PU;PA 100,75;TEXT%- CAL ATTEN DEFAULTED TO 0'S     %;
PU;PA 100,65;TEXT%- PRE-AMP GAIN DEFAULTED TO 0'S   %;
PU;PA 100,55;TEXT%- AMP CORRECTION DEFAULTED TO 0'S  %;
WAIT 2;IP;MENU 1;
FUNCDEF R_EVDATE,@
PU;PA 50 185;TEXT%      LASTEST DLP REV. DATE: 01/12/97%;
PU;PA 50,60;TEXT%          PRESS ENTER AFTER VIEWING%;
HD;EP;MPRST;
MN1;
FUNCDEF S_CAP,@
$;ANNOT OFF;GRAT OFF;BLANK TRA;CLRDSP;MN0;CSIZE 1,1;PU;PA; 200, 50;PD;PR;110,70;90,0;0,-70;-25,0;0,-15;25,0;0,-40;-200,0;0;55;PU;10,-50;TEXT%o%;PU;150,100;TEXT%o%;DRAWBOX  250, 35, 265, 25,5,5;CSIZE;PU;PA; 125, 135;PD;PR;55,0;70,-100;4,10;-4,-10;-15,5;PU;PA;120,200;TEXT%Verify Super-Cap Voltage%;PU;PA;120,190;TEXT%========================%;PU;PA;-10,170;TEXT%- Lift the edge of the shield on%;
PU;PA;-10,160;TEXT%  the memory board.%;
PU;PA;-10,150;TEXT%- Touch the test fixture probe to%;
PU;PA;-10,140;TEXT%  the square pad of C1 on the%;
PU;PA;-10,130;TEXT%  memory board.%;
PU;PA;-10,120;TEXT%- The LED in the%;
PU;PA;-10,110;TEXT%  test fixture must%;
PU;PA;-10,100;TEXT%  light for the board%;PU;PA;-10,90;TEXT%  to PASS.%;PU;PA;-10,80;TEXT%- Press ENTER when done.%;HD;EP;MPRST;MN1;
FUNCDEF D_ONE,@
MENU 0;
BLANK TRA;ANNOT OFF;GRAT OFF;CLRDSP;
PU;PA,100,150;TEXT%WARM-UP DONE%;
PU;PA,160,120;TEXT%CAL. FREQ/AMP DONE%;
PU;PA,250,25;TEXT%PRESS ENTER TO EXIT%;
PU;
PA;100,100;PD 100,150;
150,150;100,100,100;
150,150;150,100,100,100;
PU;
EP;IP;MENU 1;
ANNOT ON;
TITLE%WARM-UP DONE%;
ERASE;
FUNCDEF C_PU,@
VARDEF F_FLAG,0;
TRDEF TRA_A,401;
VARDEF ADC_LO,0;
VARDEF ADC_HI,8000;
VARDEF F_HI,0;
VARDEF F_LO,0;
DET GND;TS;MOV ADC_LO,MEAN TRD;PU;PA 150,45;
TEXT%ADC GND=%;PU;PA 250,45;DSPLY ADC_LO,5.0;
PU;PA300,45;IF ADC_LO,GT,135 THEN TEXT%FAILED%;
MOV F_FLAG,1;MOV F_LO,1;ENDIF;
PU;PA300,45;IF ADC_LO,LT,45 THEN TEXT%FAILED%;
IF F_LO,EQ,0 THEN TEXT%ok%;ENDIF;
DET REF;TS;MOV ADC_HI,MEAN TRD;PU;PA 150,35;
TEXT%ADC 2V =%;PU;PA 250,35;DSPLY ADC_HI,5.0;
PU;PA 300,35;IF ADC_HI,LT,3430;THEN TEXT%FAILED%;
MOV F_FLAG,1;MOV F_HI,1;ENDIF;
PU;PA 300,35;IF ADC_HI,GT,3630;THEN TEXT%FAILED%;
IF F_HI,EQ,0 THEN TEXT%ok%;ENDIF;
GRAT OFF;BLANK TRA;MENU 0;
PU;PA 150,25;TEXT%ENTER DATE:%;DATEMODE MDY;
TIMEDSP ON;SETDATE EP;PU;PA 260,25;TEXT%Done%;
PU;PA 150,15;TEXT%ENTER TIME:%;
SETTIME EP;PU;PA 260,15;TEXT%Done%;
IF F_FLAG,EQ,0 THEN
IP;
PU;PA 50,175;TEXT% ******* CPU PRETEST PASSED ******** %;
PU;PA 50,135;TEXT%           CYCLE THE POWER           %;
PU;PA 50,115;TEXT%      TO ENSURE THE CPU COMES UP     %;
PU;PA 50,95;TEXT%       WITH THE CORRECT DISPLAY       %;
ELSE
IP;
PU;PA 50,185;TEXT%      FAILED .................       %;
PU;PA 50,175;TEXT%      ............FIX & RETEST       %;
PU;PA 50,155;TEXT%      PRESS ENTER TO EXIT SCREEN     %;
ENDIF;EP;IP;MENU 1;
FUNCDEF W_ARM,@
CLRDSP;
PU;PA,15,190;TEXT%********** WARM-UP DLP ************%;
MOV T_REG,TIMEDATE;
MOV T_IME,T_REG;
MOV Y_EAR,T_IME;
INT Y_EAR,Y_EAR;
PU;PA,45,130;TEXT%START TIME= 19%DSPLY Y_EAR,2.0;TEXT% YEAR%;
MOV T_IME,T_REG;
MOV M_ONTHS,T_IME;
PU;PA,157,120;DSPLY M_ONTHS,2.0;TEXT% MONTH%;
MOV T_IME,T_REG;
MOV D_AYS,T_IME;
MPY Y_EAR,Y_EAR,100
INT D_AYS,D_AYS;
PU;PA,157,110;DSPLY D_AYS,2.0;TEXT% DAY%;
MOV T_IME,T_REG;
MOV H_OUR,T_IME;
MPY Y_EAR,Y_EAR,100
INT H_OUR,H_OUR;
MOV H_REG,H_OUR;
 IF H_OUR,LT,1 THEN
   ADD H_OUR,H_OUR,12;
   SUB A_MPM,A_MPM,1;
 ENDIF;
 IF H_OUR,EQ,12 THEN
   ADD A_MPM,A_MPM,1;
 ENDIF;
 IF H_OUR,GT,12 THEN
   SUB H_OUR,H_OUR,12;
   ADD A_MPM,A_MPM,1;
 ENDIF;
 IF A_MPM,EQ,-1 THEN
   PU;PA,157,100;DSPLY H_OUR,2.0;TEXT% AM%;
 ENDIF;
 IF A_MPM,EQ,0 THEN
 ENDIF;
 IF A_MPM,EQ,1 THEN
   PU;PA,157,100;DSPLY H_OUR,2.0;TEXT% PM%;
 ENDIF;
MOV T_IME,T_REG;
MOV M_IN,T_IME;
MPY Y_EAR,Y_EAR,100
INT M_IN,M_IN;
MOV M_REG,M_IN;
PU;PA,157,90;DSPLY M_IN,2.0;TEXT% MINUTES%;
MOV T_IME,T_REG;
MOV S_EC,T_IME;
MPY Y_EAR,Y_EAR,100
MPY M_IN,M_IN,100;
INT S_EC,S_EC;
MOV S_REG,S_EC;
PU;PA,157,80;DSPLY S_EC,2.0;TEXT% SECONDS%;
Sending this up through GPIB will create the menu entries and DLP.
I think this is some service/diagnose personality.
This shows that one can rebuild most of the stuff from the USTATE? dump. The difficult part is to actually guess the filenames!
I'm pretty happy that I got this back to work - for no particular reason.
My only doubt is if some DLP or commands within require variables I have not created.
I would like to suggest to describe personalities like the above code, as it can be sent to the device with great ease - I think I could use Keysight Interactive IO and just do a COPY&PASTE and it would work.
Regards,
Vitor
Offline xwarp
« Reply #35 on: March 24, 2019, 02:27:03 am »
I thought that I had read somewhere that there were some components that had to be changed out for the 75 ohm to 50 ohm use.
Offline kawal
« Reply #36 on: April 28, 2019, 04:06:01 pm »
nice software.
I just got a broken 8591A which I managed to repair (power switch was defective). I will try the  software you provided. I assume this is over GPIB  ?
Offline Bicurico
  • Country: pt
« Reply #37 on: April 28, 2019, 06:15:43 pm »
Yes. And you need to install Keysight Connection Expert 2018.
Regards
Vitor
The following users thanked this post: kawal
Offline kawal
« Reply #38 on: April 28, 2019, 07:16:37 pm »
do i need to register the software anywhere ?  Tried it and asking for a code.
