After testing it for a while, here is my preliminary conclusion on the ST42.
+ Very narrow construction factor
+ Very fast measuring speed, the fastest I have experienced to date.
+ Still accurate, within its own tolerance
+Outstanding display, nothing can beat OLED
+L measurements included, many measuring tweezers only offer R and C.
+Additional parameter displays
+Dedicated ESR mode
+DC resistance mode
+open/short calibration option as with the "large" lcr meters
+Excellent operation with a single element, the multi-way joystick.
Virtually blind operation after a short familiarization period.
+Display: right/left-handed mode
+Overall a well thought-out concept
+Excellent: 4-wire design up to the measuring tips
+Firmware update option
+Very good support, continuous updates
+Excellent price/performance ratio
O Design-related mechanical restriction with regard to the components to be measured
O Battery operation: Unclear situation regarding the battery used, is it replaceable, is it a regular type available everywhere?
O Measuring frequency maximum 10kHz, no disadvantage, because it shows that the developer is aware that higher frequencies entail other circuit requirements that could not be met due to the design, other suppliers could take an example from this.
- Housing processing in the display area
- No local distributors, only available via Aliexpress
I was attracted to these measuring tweezers because so many people were so enthusiastic about them.
I tend to be skeptical about such praise, but I was pleasantly surprised.
The measuring speed is breathtakingly fast, the accuracy is good considering the design, although not outstanding, and the OLED display does an excellent job.
For the money an excellent device which has now rendered my Mastech LCR measuring tweezers out of work, the ST42 is simply outstanding in comparison.
For
me, however, the ST42 is not a complete replacement for all LCR measurement tasks, as the measurement voltages/frequencies/currents are too low and the tolerances in terms of accuracy are too high.
But I think it would be perfectly adequate for 80...85% of all users and makes a further investment superfluous.
Especially if Shannon would take up my idea regarding adapters for larger measuring objects and offer a purchasable alternative.
Anyone who has been considering a DER DE-5000 should take a closer look at the ST42.
My personal LCR Meter ranking:
-ET35
-ST2830
-ET45
-ST42
-ET44
-DE5000
Summary: Good !
Martin
