The devil is in the detail.....
I thought to myself, now you're going to make something nice to rebuild, something that has hands and feet and extends the tweezers - why don't you make adapter cables with test hooks so that you can also test large components.
No sooner said than done, it hardly costs anything, looks good and fits perfectly.
If it weren't for one tiny little pitfall.
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
After attaching the cables, the ST42 shows short circuits everywhere - why...
Quite simply, the small screws must be screwed in insulated, because of the Kelvin functionality....Cool.
Never mind, just make the holes in the blades a bit bigger - or use an original set of blades from Shannon.
Either way, I think this is the more “professional” solution to extend the tweezers instead of just wrapping wire around them.
I will present the final solution soon.
