I got a HP6268B off the e place and it was listed as untested. In the few published pictures it looked like it was in decent shape, and everything there that should be at least externally. I sent in a low offer and it was accepted, best of all shipping had been listed as free. Or was it...
As you can guess that free shipping option was probably not a good idea after the seller found out what it would cost him to ship 80+ pounds. So he put it inside a flimsy cardboard box and a little cushioning on top and bottom of the box, but really very little on the sides. Needless to say it got damaged along the way. Probably some pissed off UPS worker that really was unable to handle the box must have dropped from at least from 3ft. Can't really blame this person, as the box which was barely larger than the power supply itself, no handles and poorly packed, was really unmanageable. During the fall the sharp edges of the front panel chewed its way out of the box so what I received was a big mess. Front panel bent at two corners, one handle bent slightly sideways , plus various dents, scratches and bent metal at several other areas. The rear junction block where the remote programming and sensing wires connect is bent upwards, but luckily nothing broken nor has the PC board suffered any damage. Fortunately the meters where still intact, and the front knobs and more importantly the controls seemed to be ok. Two of the knobs seem to have lost its cap but that was the way it was shown in the listing, but the two other knobs survived.
There was also some sort of rattling like loose parts towards the rear when the equipment was turned over, but I could not see anything moving around or make it fall out. This turned out to be inside the red RFI assembly box, where 3 out of 4 spacers where broken off and there where some loose screws as well, along with various washers. So far found everything except for the last screw that holds that cover in place. Out of the 4 screws that hold that cover 2 where missing. Its like some hamfisted dolt forced his way in there and in the process broke several threads made of soft aluminum, just to then hastily threw everything back together. This could not have happened due to the recent tumbles in shipment.
I noticed that one of the broken off spacers is what actually completes the connection between one of the inbound AC sides and the Triac that is part of the preregulator, so this power supply could have never worked this way, I wonder if this might have been be the problem and the reason it was listed as "untested". I checked the Triac and it is ok. On the board inside the preregulator red box there are 3 RIFA caps which looked very crazed, one even having a gash on the side.
First thing was to re-strap the power supply for 115V for testing, as I don't have 230V at my bench. this involved reconfiguring both transformers T1 the (huge!) main and T2 the bias transformers. Also two jumpers need to be added and one removed, plus a 390 ohm 2W resistor needs to be added as well on the RFI assembly board.
Then tested the power supply by substituting the triac with a light bulb to prevent any big surges or possibly any shorts from causing fireworks, and it basically came up and regulation seemed was working fine as I was able to vary the voltage from zero to almost up to 40V. I was thrown off for a while and stuck at zero output because had not noticed that both current controls where set to minimum, which basically prevents the supply to provide any output voltage at all. So this fixed that, but then the overvoltage started triggering, and again by just setting the front panel adjustment to fully CW solved that. I was even able to connect a 12V car bulb that draws 0.5Amp and it was holding fine, but anything above 1amp caused the voltage to slowly fall back. Given that the whole preregulator is out of the loop, and the light bulb in place of the triac was only allowing about 75V AC to reach the transformers, that should be normal for now.
So needed to order the replacement for the 3 RIFAS, and also all the electrolytic caps on the A1 main board. One of the bigger caps (orange one) on that board clearly has outgassed on one side, but no signs of corrosion. There are in total perhaps under a dozen caps on the board total that will be replaced. They all look to be from the 80s given their size to value ratio.
Some nudie pictures attached.
