Specs say the DSOX1204A has 1Gsa/s sample rate when all 4 channels active; GDS-2074E appears to be 2Gsa/s across all channels, so 500Msa/s when all 4 channels in use.
Also, the latest DSOX firmware enables 500 segments (see https://www.eevblog.com/forum/testgear/new-keysight-dsox1200x-and-edux1052-scopes-with-extended-capabilities/msg2951870/#msg2951870).
Thank you for that information. That IS much better and more useful..
And no not some random differences to GW Instek. GW Instek is literally better designed scope from ground up, having much more capabilities, search, measurements, statistics with histograms.
GW Instek is really bad at marketing, you need to download user manual to actually see all the stuff you can do... If it weren't for lower bandwidth and sampling rate and less protocols (not problem mostly all important are there for general purpose work) it would give MSOX 3000A run for it's money, as far as math, measurements, and analytical features.. MSOX3000T doesn't have histograms, for instance...
DSOX1204 is severely limited compared to it.
But hey, like I said before, I'm not trying to convince you anything. Just making facts straight. It was obvious from the start you're going to buy Keysight.. It's your choice. It's a very nice, very good analog replacement scope. It's not bad choice, just not best buy, capability wise. I guess brand name does have value after all.
