Author Topic: Serial to usb on Kunkin KP184 electronic load  (Read 60837 times)
Offline interflexo
  • Country: pt
Re: Serial to usb on Kunkin KP184 electronic load
« Reply #225 on: March 11, 2024, 10:03:55 am »
Yes. The KP184 Modbus Software is compatible with Windows 11.
Please check the drivers of your USB to Serial Adapter for any issues regarding Windows 11.
« Last Edit: March 11, 2024, 10:16:11 am by interflexo »
Offline rallyhard
« Reply #226 on: April 21, 2024, 06:56:39 pm »
Thank you to the forum admins for maintaining this excellent resource.
I bought Interflexo’s software and find it useful, but have a bit of an issue that I was wondering if anyone else has. I tried asking Interflexo/Manuel, but haven’t heard back yet.
We use the KP184 along with the PC software to perform discharge tests on deep cycle lead-acid batteries. It works well except that during the test, the voltage will occasionally dip severely for a very brief moment and then continue normally. The test bench is not being disturbed when this happens. I’ve tried wiggling the wires between the unit and battery during the test to see if there is a bad connection, but the voltage doesn’t change at all when I do that. It happens randomly during tests whether using remote or local sense. The dip in voltage will eventually cause the test to end early as it dips below the test end voltage, so I have to keep restarting it.
Thanks for any input.  :)
EDIT: Here are the test reports showing the voltage dips:
https://i.postimg.cc/JtC8kjR3/kp184-Report1.png
https://i.postimg.cc/6qvwqMx5/kp184-Report5.png
« Last Edit: April 21, 2024, 10:20:17 pm by rallyhard »
Offline interflexo
  • Country: pt
« Reply #227 on: April 25, 2024, 04:59:48 pm »
No other customer complains about this. It must be hardware specific.
Does this happen with only one specific lead-acid battery or with other ones as well?
Does this happen with a Li-ion battery / LFP battery  / DC Power supply discharge tests as well? Please do some similar basic tests with your system to rule out the device being tested.
What USB to Serial adapter are you using?
Sometimes lead-acid battery internal serial busbar connections get corroded, break and show a similar behaviour.
On one of your test reports the reason for the end test was Kunkin KP184 shut the load OFF (not the software).
On these long tests the Windows system power settings should be configured to not interfere with the on going test.
Can you use an oscilloscope and do a trigger test with a low voltage (Ex: 11V) to make sure the quick voltage dips are not real?
« Last Edit: April 26, 2024, 03:04:44 am by interflexo »
Offline korjaa
« Reply #228 on: April 26, 2024, 05:52:19 pm »
Hello,
I recently bought one of these KP184s and I've been using it to test Ryobi drill batteries. I have also noticed that occasionally I get spikes, usually downwards, but there have been few upwards also.
Example of downward spike (0A...10A toggling, 15 period):
2144782-0
Example of upward spike (0A...15A toggling, 15s period:
2144788-1
0A...5A toggling causes periodic spikes?
2144794-2
The message checksum is checked, so the data should be OK. I know the checksum is calculated as I spent a while debugging it. The source is available in https://github.com/korjaa/kunkin-kp184, in case anyone is interested. I have not inspected the waveform with a scope to verify if the spike is real.
Mine are Li-ion batteries, 5s2p
Multiple batteries for me.
Update:
Tried scoping the waveform, wasn't able to catch the spike during test. I did however noticed that if the load is small 100mA/10mA/0A, there is actual ~2V..3V dip in the voltage occasionally, maybe every 30s. The spike period matches with my earlier 0A...5A toggling test.
2145031-3
It does not happen if I disconnect the battery from KP184. The downward slope of the spike is related to the current.
Below are some spike lengths measured with different load values:
Output OFF -- 200ms (happens even with the output off)
8mA -- 1ms...6ms
30mA -- 200us...300us
100mA -- 60us...80us
500mA -- 40us...60us
700mA -- 40us
1A -- couldn't get it to trigger in few minutes.
« Last Edit: April 26, 2024, 07:39:04 pm by korjaa »
Offline interflexo
  • Country: pt
« Reply #229 on: May 09, 2024, 09:19:56 am »
From the information above the problem does not seem to be related to the data acquisition software as it happens with different software developments around the same Modbus protocol.
The Kunkin serial interface even at 115200 is slow you won't get more than 5 complete data sets every second.
Even the 250us voltage dips should not make much difference on a 200ms data acquisition period.
I think I will add to the KP184 Modbus Software a user configurable minimum amount of time for the acquired voltage to be below the battery test end voltage, trigger the test end condition and call it a day.
I also think this must be somewhat hardware related (KP184 Hw version) because I have hundreds of very long battery discharge data acquisition tests and never seen this happen even once.
Please pay attention to the KP184 4 mm binding posts odd internal diameter that can cause sketchy electric connections. I always use fork crimped cable connections screwed on the back of the binding posts to avoid nuisances.
« Last Edit: May 09, 2024, 09:47:37 am by interflexo »
Offline rallyhard
« Reply #230 on: May 16, 2024, 06:47:59 am »
Hi, thank you for the reply.
This happens on every battery we test, which has been about 10 different deep cycle lead-acid batteries. I just tried testing a couple Ryobi 18v Lithium-Ion power tool batteries (as korjaa did after your reply), and also got voltage dips. Interestingly, the dips when testing these batteries (I tried 2) were at regular intervals; about once a minute.
We are using this USB to serial adapter:
https://www.amazon.com/gp/aw/d/B076WNJLLV/ref=ya_aw_od_pi?ie=UTF8&psc=1
Yes, on one of the previous screenshots I shut the test off manually instead of letting it complete.
Unfortunately, I don’t have an oscilloscope to check with.
We are using ring terminals to connect the test leads, not banana plugs.
I’m considering buying a second KP184 to speed up the testing procedure when we have multiple batteries to test at once, and am heartened to hear that this isn’t a common issue with the unit.
It would be great if you could implement an option in the software to have a setting for a minimum amount of time below the test end voltage. That may provide a workaround for our issue and allow us to continue using this unit. It is out of warranty and I don’t know how else to approach the problem.
« Last Edit: May 16, 2024, 05:07:58 pm by rallyhard »
Offline rallyhard
« Reply #231 on: May 16, 2024, 06:53:01 am »
Voltage dips on 18v Li-Ion battery test
https://i.postimg.cc/MHT9N0qv/IMG-9844.jpg
Offline interflexo
  • Country: pt
« Reply #232 on: May 17, 2024, 10:02:15 am »
I will do it ASAP.
Do you have a suggestion for this default minimum amount of time as per your observations?
From your last plot and counting the voltage dips: Did you make sure you are not requesting the periodic internal resistance test during the battery capacity discharge test? You can use the right mouse button on the Batt Tab mouse icon the access the context menu and check for it (user manual page 28). If you were it would look much like that...
Unrelated: Any particular reason for not be using the latest 1.0.66.0 version?
« Last Edit: May 17, 2024, 10:17:38 am by interflexo »
Offline rallyhard
« Reply #233 on: May 17, 2024, 08:47:22 pm »
Checking the CSV files of tests for the voltage dips, it appears to only dip for one sample. So, it looks like a one second minimum would suffice in my case, or maybe even a 2-sample minimum.
The internal resistance test is turned off.
There’s no reason I’m on an older version; just haven’t gotten around to updating.
I noticed while checking the CSV files that the Li-Ion battery test dips on exactly 1 minute intervals, to the second. I wonder if this could have to do with the battery’s internal BMS. I followed up with another test of a lead-acid car battery and it didn’t dip until 10.5 minutes.
Offline interflexo
  • Country: pt
« Reply #234 on: May 20, 2024, 04:27:10 pm »
New KP184 Modbus Software Version 1.0.67.0:
Setup KP184 Software V1.0.70.0
User_Manual
Changes:
1. New options on battery capacity discharge test tab right mouse button context menu for an optional low voltage cut-off 1,5s detection delay. This avoids battery capacity test premature ending on quick voltage dips.
« Last Edit: July 11, 2024, 09:57:51 am by interflexo »
Offline interflexo
  • Country: pt
« Reply #235 on: May 22, 2024, 08:24:26 am »
New KP184 Modbus Software Version 1.0.68.0:
User_Manual
Changes:
1. Some events handling were blocked during right mouse button context menu display. Corrected.
2. CVL (Constant voltage current limited) test mode manual startup load ON event triggers now the automatic data acquisition.
« Last Edit: July 11, 2024, 09:58:22 am by interflexo »
Offline interflexo
  • Country: pt
« Reply #236 on: May 28, 2024, 03:16:46 pm »
New KP184 Modbus Software Version 1.0.69.0:
User_Manual
Changes:
1. New software CWL mode with current limiting capability. Operates Kunkin in CC (constant current) mode and a PID configurable control loop holds the configured CW (constant power) setting by permanently adjusting the CC load.
2. Several Python support modules were updated.
« Last Edit: July 11, 2024, 09:58:51 am by interflexo »
Offline rallyhard
« Reply #237 on: June 04, 2024, 02:04:32 pm »
The new low-voltage cutoff delay seems to be working to keep the test running through the dips! Thank you so much for adding this functionality.
If I buy a second KP184 and serial-to-USB adapter, will the software recognize the additional unit? Will I need to run a second instance of the program, or how does that work?
Offline interflexo
  • Country: pt
« Reply #238 on: June 04, 2024, 06:13:11 pm »
Hi. Thanks for the feedback.
The KP184 has no programmatically accessible internal serial ID.
The software is tied to the PC hardware. When required I supply new reg keys.
You can run unlimited instances of the same software application on the PC. Each software instance selects a different USB to Serial Adapter.
I will have a new version to run multiple paralleled KP184s on the same PC software for high power applications as if you have just one really powerful unit.
« Last Edit: June 06, 2024, 07:54:20 am by interflexo »
Offline interflexo
  • Country: pt
« Reply #239 on: July 03, 2024, 07:02:24 pm »
New KP184 Modbus Software Version 1.0.71.0:
Setup KP184 Software V1.0.71.0 32-bit
Setup KP184 Software V1.0.71.0 64-bit
User_Manual
Changes:
1. Added user selected value annotations on the test plot graphs.
2. Corrected an issue related to the current timezone access.
3. Added a new 64-bit version. 32-bit/64-bit versions need Win 7 and up.
The 32-bit and 64-bit versions have different installers and uninstallers. Both versions share however the data folders and .ini defaults file.
User selected value annotations on the plot graph
The user can use the left mouse click on the plot graph area during the test and after the test completion to select a point. This point will define an x value to get the y curve values and the final position to the arrow of text annotation.
Left mouse click deletes the last annotation and creates a new one on the selected point. Useful to iterate the best position for an annotation.
Shift + Left mouse click adds a new annotation on the selected point inside the plot graph area. Does not need to be selected on top of the curves. There is no limit for the number of annotation that can be created this way.
Backspace + Left mouse click anywhere inside the plot graph area deletes the last annotation created. Works like an undo. Any number of annotations can be deleted sequentially this way. The user can’t select a random annotation to delete.
Right mouse click anywhere inside the plot graph area deletes all the annotations created in a single operation.
The annotations are automatically deleted when a new plot graph is started at the beginning of a test.
When the plot graph x scale changes from seconds to minutes (at the 3-minute mark) and from minutes to hours (at the 2-hour mark) during a test the annotations are erased. New ones can be created after the event.
The annotations will become integral of the plot graph and will be displayed on the PDF, images, and test reports plot graph.
« Last Edit: July 03, 2024, 07:08:49 pm by interflexo »
Offline interflexo
  • Country: pt
« Reply #240 on: July 15, 2024, 08:38:03 am »
New KP184 Modbus Software Version 1.0.72.0:
Setup KP184 Software V1.0.72.0 32-bit
Setup KP184 Software V1.0.72.0 64-bit
User_Manual
Changes:
1. V1.0.71.0 32-bit failled to run on some Win 7-10 32-bit systems. Fixed.
Offline interflexo
  • Country: pt
« Reply #241 on: August 05, 2024, 05:08:31 pm »
New KP184 Modbus Software Version 1.0.73.0:
Setup KP184 Software V1.0.73.0 32-bit
Setup KP184 Software V1.0.73.0 64-bit
User_Manual
Changes:
1. Application popup windows were showing up on the wrong monitor on multiple monitor configurations. Center of the application window is now used for the popup windows location.
2. On the battery capacity discharge test PDF report when using constant power load mode the units on the “Load Set:” and “Discharge Current/Power:” fields were wrong.
