Author Topic: Serial to usb on Kunkin KP184 electronic load  (Read 60823 times)
linhgiangloc and 1 Guest are viewing this topic.
Offline interflexo
  • Country: pt
Re: Serial to usb on Kunkin KP184 electronic load
« Reply #125 on: April 03, 2021, 12:19:42 pm »
New KP184 Software Version 1.0.21.0:
Changes:
1. LCD Panel uses a new 7 segment display monospaced font
Pros: String does not shift around when '1' char is used
Cons: Decimal separator takes as much space as an '8''
Setup KP184 Software V1.0.70.0
« Last Edit: July 11, 2024, 09:35:56 am by interflexo »
The following users thanked this post: 1001, lnxpro
Offline Treed
« Reply #126 on: April 10, 2021, 08:23:59 pm »
Wow, I haven't looked at this thread for a while, assuming the forum would notify me of new posts and now I come back and everything is solved! Great job RhdZ!
Offline adso85swe
« Reply #127 on: April 13, 2021, 08:23:31 am »
I have been looking around for a good value electronic load and being able to log data on a computer has been an important criteria. More or less a showstopper if no software exists.
Reading about your software development Interflexo is really making me consider getting the Kunkin KP184. Amazing work, such a nice contribution to the community. If I end up getting the elecronic load, I will most definitely go through the registration of your software.
Offline HKJ
    • Tests
« Reply #128 on: April 13, 2021, 08:42:36 am »
If you only want data from the load on your computer this software is good, but if you want more devices connected check: https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/, it supports many different loads and other devices.
The following users thanked this post: interflexo
Offline adso85swe
« Reply #129 on: April 13, 2021, 09:41:12 am »
Ok, very cool  8). Since I own a Uni-T UT61D multimeter and a Riden RD6006 power supply this software would also make a lot of sense to me. So many good option out there. Amazing forum really :)
Offline interflexo
  • Country: pt
« Reply #130 on: April 14, 2021, 09:18:22 am »
Thanks. Kunkin KP184 panel operation and configuration menus are a bit cumbersome, the software allows a clear and straightforward operation with many extra features.
Offline jasom
  • Country: sk
« Reply #131 on: April 17, 2021, 10:38:06 am »
 interflexo: Hello, I got a problem with connect from Your app. Connection from modbus is without problem but in windows app I has only some like this
17/04/21 12:37:22 Connected to COM port
17/04/21 12:37:27 Closed COM port
17/04/21 12:37:27 KP184 not found
But on same port I can connect from modbus. Can You help me?
Thank You
Edit: Ok, with decrease baud speed its working now.
« Last Edit: April 17, 2021, 12:04:06 pm by jasom »
Offline interflexo
  • Country: pt
« Reply #132 on: April 19, 2021, 06:14:01 pm »
I am glad you worked it out Jasom.
You must always configure (baudrate and address) the software to match the operating panel menus configuration from your Kunkin.
Offline F64098
« Reply #133 on: April 19, 2021, 08:59:08 pm »
I also had problems with higher baudrates.
Even when using a short cable and the com-port of the mainboard.
Best regards
Frank
Offline interflexo
  • Country: pt
« Reply #134 on: April 23, 2021, 11:28:07 am »
New KP184 Software Version 1.0.22.0:
Changes:
1. Enhanced battery DCIR test. The first step may be configured to 0A to measure the battery internal resistance from an open circuit voltage (OCV) state. The step pulse time is configurable to meet specific user needs. Thanks adso85swe for the insight regarding DCIR test.
Updated User Manual
« Last Edit: July 11, 2024, 09:36:25 am by interflexo »
Offline interflexo
  • Country: pt
« Reply #135 on: April 27, 2021, 09:34:49 am »
New KP184 Software Version 1.0.23.0:
Changes:
1. Enhanced battery DCIR test. Both pulse step times are now configurable. These tests can now meet IEC 62620 standards for Li-ion batteries and IEC 61951-2 standards for Ni-MH batteries.
2. Application load time was cut to one third.
Updated User Manual
« Last Edit: July 11, 2024, 09:36:56 am by interflexo »
Offline lnxpro
« Reply #136 on: April 27, 2021, 05:40:21 pm »
1.0.23.0 gives me an error on launch that it can't access the ini file.
happens with admin rights (run as admin) or normal without admin rights
Offline interflexo
  • Country: pt
« Reply #137 on: April 27, 2021, 07:52:32 pm »
lnxpro I was not able to reproduce the same error on Win 10. You' ve got to help me here.
What is your OS version?
Is it a fresh installation or you are upgrading from a previous version? In the case of an upgrade, what was the last version?
I assume the configuration file is not found on the referenced folder. Have you confirmed it?
Anyone else found this problem?
« Last Edit: April 27, 2021, 08:51:20 pm by interflexo »
Offline lnxpro
« Reply #138 on: April 28, 2021, 02:29:57 am »
it was an upgrade from 1.0.21.0
i did confirm the file is there.
this on windows 10 LTSC version 1809
I will try a clean install and see if the issue persists.
Offline lnxpro
« Reply #139 on: April 28, 2021, 03:29:09 am »
tried a clean install of 1.0.23.0
same thing. the ini file is in the referenced folder (gets created during install), I can open it with notepad, etc.
I then installed version 1.0.21.0 back on top of the version .23 and version .21 works fine.
I also tried version .22 and it works fine. if I go to .23, it gives me the same error so for the time being I am back on version .22
Offline adso85swe
« Reply #140 on: April 28, 2021, 09:47:05 pm »
Strange. I am running v.23 without any startup issues at all  ???
Offline interflexo
  • Country: pt
« Reply #141 on: April 28, 2021, 11:32:21 pm »
Dear lnxpro the issues regarding file names I think they are related to the new distribution format [multiple files (fast app load time)] vs [single exe file (slow app load time due to lots of unpacking at startup)] because there were no code changes related to these mishaps.
Please uninstall and try the version below, it is the same code on the previous working single exe file distribution format.
Please let me know how it works for you.
« Last Edit: July 11, 2024, 09:37:22 am by interflexo »
Offline lnxpro
« Reply #142 on: April 29, 2021, 02:26:09 am »
same issue with the onefile. says it fails to process the .ini file. this was on a clean install and the file gets created by the installer.
once again, version .22 works fine.
Offline interflexo
  • Country: pt
« Reply #143 on: April 29, 2021, 09:31:19 am »
New KP184 Software Version 1.0.24.0:
Changes:
1. Back to one exe file distribution. Unpacked folder distribution causes problems accessing the .ini file. This will be sorted out later.
2. When a new configuration key was added to an older .ini file, example "inres_pulse_time2" from version 22 to 23 the error message "Can't access the .ini" was not adequate, there is a new popup message stating that one or more configuration keys were added.
lnxpro this should take care of your issues.
« Last Edit: July 11, 2024, 09:37:41 am by interflexo »
The following users thanked this post: lnxpro, adso85swe
Offline lnxpro
« Reply #144 on: April 29, 2021, 04:29:05 pm »
awesome. yes. version .24 works :)
thanks
Offline PaWill68
  • Country: ru
« Reply #145 on: May 12, 2021, 08:19:07 am »
Hello interflexo. I know you have completely figured out the Kunkin protocol. I study it too. I cannot understand how the capacity value is converted. Can you help me understand this?
I get the following data from KunkinSW
01 03 1F 03 05 00 0D C1 00 07 D0 00 07 D0 00 FA 00 FA 00 07 D0 00 00 00 00 0A F0 00 09 C4 00 00 22 A3 C8 A6 1B
Where
00 09 C4 00 = ~ 0.178Ah
00 22 A3 C8 = ~ 0.63Wh
How are these values obtained? Normal HEX> DEC doesn't work. (I tried in windows calculator)
Offline interflexo
  • Country: pt
« Reply #146 on: May 12, 2021, 07:12:41 pm »
The units are mAs and mWs.
The following users thanked this post: PaWill68
Offline interflexo
  • Country: pt
« Reply #147 on: June 06, 2021, 10:43:02 am »
New KP184 Software Version 1.0.25.0:
Changes:
1. An optional Beep on load ON/OFF was added to the configuration page. Beeps are annoying but on remote operation it is nice to receive a notification when battery discharge is over.
« Last Edit: July 11, 2024, 09:38:30 am by interflexo »
Offline TymerTopCat
« Reply #148 on: June 12, 2021, 12:34:08 pm »
The version: 1.0.25.0. Does not seem to work for me. I have a Ver:05 2020/12 Board.
However, 1.0.25.0 does work with my older 1801 Kunkin.
Additionally I am able to get the 2020 Kunkin to respond using My own C# Software and using HTerm by changing the CRC byte order.
« Last Edit: June 12, 2021, 12:43:10 pm by TymerTopCat »
Offline aristarchus
« Reply #149 on: June 12, 2021, 12:57:26 pm »
https://www.eevblog.com/forum/testgear/serial-to-usb-on-kunkin-kp184-electronic-load/msg3492100/#msg3492100
https://www.eevblog.com/forum/testgear/serial-to-usb-on-kunkin-kp184-electronic-load/msg3492512/#msg3492512
