Author Topic: seek multimeter that not eat batteries or turn off  (Read 4182 times)
Offline huggybear404Topic starter
  • Country: no
« on: April 11, 2023, 12:56:26 am »
Looking for meter that keep running a full workday without scream at me after 3 mins and turn off when I have hands stuck inside high voltage equipment, not the most ideal time to beep and make me jump... and also not bankrupt me or cost an amount that will never make me dare use it.
Is the XDM1041 a good choice or are there better options in same or lower price range ? I tryed ask seller if this will stay on or beep to interrupt me
but none knew the answer and it says nothing in manual about it. Any serious issues that should make me not order this ? does it use only internal 5v supply ? maybe add battery inside to keep it running for days even without needing the grid is a good idea ?
I tryed several handheld meters and seems all of them stay on max 5 mins before turn off so every time I want measure I have to restart it
and they still eat batteries like candy. seems almost all use aaa or 9v which is 6 of same cells. Am I the only one that think some rechargable cell is a good idea ? Tho even if I mod the cell the meter will still default to turn off. I know some meters have secret option to stay on but never remember this
setting.
one idea I have is using cheap ebay meters and a 5v mobile power adapter , upside is its very cheap at a few $ in parts, it likely is not very accurate
and I fear risk of shock if the cheap china mobile chargers break down. and also will be challenge and complex to put ranging switches and resistors in a small portable box. Especially if I want option for A , V and ohms in same meter. With the low price it may be good to make one of each tho.
Any other or better options to fit my needs ? or other suggestions ?
Offline nightfire
Re: seek multimeter that not eat batteries or turn off
« Reply #1 on: April 11, 2023, 01:04:59 am »
Depends on what your requirements are. If you need an affordable bench multimeter to simply circumvent turning off, then probably yes.
If you look for special things, maybe not. As an affordable alternative to a cheap handheld modded with battery connectors (the old Flukes had this, like the old 8020A), surely yes, if you primarily probe voltages.
But: Whats your usage profile?
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #2 on: April 11, 2023, 01:05:11 am »
Are you sure that the manual for your meter does not offer a way to cancel the auto-power off? The handheld I use allows that to be turned off (UNI-T UT17B Pro).
I don't know why the meter would "eat" batteries like you are describing even when used all day. Does it have a backlit display?
Online IanB
« Reply #3 on: April 11, 2023, 01:52:32 am »
I suggest two things:
(1) Read the user manuals of prospective meters on-line to find meters that have a way to cancel the auto-power-off.
(2) Consider meters that use a 9 V battery. Because such batteries have low energy content, the meter must be designed to have low power consumption. If a meter requires 4 or 6 AA cells it is probably a power hog.
I have some RadioShack meters that satisfy points 1 and 2. I have left them switched on for hours at a time doing data logging without draining the battery. I know these particular meters are now unobtainable, but I suspect there are other meters with similar characteristics.
Offline mwb1100
« Reply #4 on: April 11, 2023, 06:43:41 am »
Approximate alkaline battery life (from the manuals - not measured by me) for some meters that are well built for being "stuck inside high voltage equipment" and that have a mechanism to turn off auto power off:
  - Fluke 87v: 400 hours
  - Fluke 179: 300 hours
  - Brymen BM235: 250 hours  (doesn't need APO to be disabled - whenever there's a reasonable reading, the APO timer is reset)
  - Brymen BM257s:  220 hours (est)
As far as I can recall every meter I've ever had that features APO had some mechanism to disable it.  A simple solution to not remembering how to do the disable is a piece of tape that you write on "Hold SELECT to disable APO" (or whatever).  Use a label printer if you want it to look nice.
« Last Edit: April 11, 2023, 06:49:41 am by mwb1100 »
Online Psi
« Reply #5 on: April 11, 2023, 06:47:41 am »
Be aware though, if you turn on the display backlight the battery life will be orders of magnitude less.
Even if you have a DMM that does not officially have a way to disable auto power off there may be an undocumented way to turn it off.
Check out what chipset the meter uses and then look up other meters with the same chipset or check out the datasheet.
« Last Edit: April 11, 2023, 06:49:27 am by Psi »
Offline Fungus
« Reply #6 on: April 11, 2023, 06:50:04 am »
Is the XDM1041 a good choice or are there better options in same or lower price range ? I tryed ask seller if this will stay on or beep to interrupt me but none knew the answer and it says nothing in manual about it. Any serious issues that should make me not order this ? does it use only internal 5v supply ? maybe add battery inside to keep it running for days even without needing the grid is a good idea ?
It's a "bench meter" so it won't beep or turn off.
There's an XDM1241 with built-in battery. I assume it's the same, read the manual...
Either that or ... get a meter where the batteries are really fast/easy to change. No screwdriver, no rubber boot to remove, etc.
eg. Fluke 187 can disable all APO and batteries are 4xAA under a door with a thumbscrew.
Option 2: Get something like a Fluke 27FM which doesn't have auto-power-off and goes for over 1000 hours on a battery. It's not a sophisticated meter but it's a good one.
The following users thanked this post: huggybear404
Offline wasedadoc
« Reply #7 on: April 11, 2023, 09:31:01 am »
The Owon 1241 does have Auto Power Off with a choice of times from 0.5 to 2 hours and disabled. The setting is retained when power cycled.
Offline BeBuLamar
« Reply #8 on: April 11, 2023, 02:27:10 pm »
[quote author=
[/quote]
With 4AA are only good for 72 hrs with backlight off in the 187/189.
Offline David Hess
  • DavidH
« Reply #9 on: April 11, 2023, 04:56:24 pm »
Older meters, even from Fluke, often ran for 2000+ hours on a 9 volt alkaline battery.  I have not seen any modern meters with long battery life.
Offline colorado.rob
« Reply #10 on: April 11, 2023, 05:10:37 pm »
Hell, my Agilent U1252A doesn't last 2000 hours powered off. I almost always have to charge it when taking it out for use. I don't have that problem with it's brother, the U1252B. (I've swapped batteries between the two, so it's definitely the meter.) Must be the color...
Offline mariush
« Reply #11 on: April 11, 2023, 05:20:24 pm »
The Uni-T UT61E has data logging enabled so it doesn't turn off... it works with a 9v battery but will function down to very low voltage levels .. could probably run it from a big battery for a long time.
but I don't think it's the best choice if you're dealing with high voltages. doesn't  have as many protections and safeties for highvoltage
Offline Fungus
« Reply #12 on: April 11, 2023, 05:36:29 pm »
I don't know what voltage the battery warning comes on at but I just measured the consumption, it uses:
~13mA without the backlight, that should be about 150 hours with a 2000mAh battery.
~43mA with half-power backlight, about 46 hours with a 2000mAh battery.
~80mA with full-power backlight, about 25 hours....
It's definitely not the most contrasty meter in the world and the screen background is quite a dark color so I'd probably want the backlight on if I was using it all day.
The annoying thing is that there's two levels of brightness so you can't turn the light on/off with a single press to save power  You have to press it multiple times.
(and the second level of brightness isn't that much brighter.  >:( )
Bottom line: You'd be changing the batteries once a week if you were using it all day. It only takes about ten seconds to do, so...  :-//
« Last Edit: April 11, 2023, 05:45:18 pm by Fungus »
Offline bdunham7
« Reply #13 on: April 11, 2023, 05:53:50 pm »
Later model Fluke 27 with the grey face and CAT III/1000V rating.  Easy-to-read high contrast LCD (without backlight), extremely durable, no APO and runs for thousands of hours on a 9V battery.  Available in mint condition for $100 or so on eBay.
The following users thanked this post: Fungus, mwb1100
Offline nctnico
« Reply #14 on: April 11, 2023, 06:29:41 pm »
Owon stuff doesn't get much love over here because it typically is lacking where it comes to the finishing touches in the firmware.
I have a couple of Vici VC8145 bench multimeters to address the same problem you have. I have these for about a decade already. They look a bit less sexy compared to the Owon but work very well, have a nice big backlit display and these are stackable.
There are also the Aneng AN888 / AN999 bench multimers which look interesting.
Offline Fungus
« Reply #15 on: April 12, 2023, 02:46:36 am »
Review here: https://lygte-info.dk/review/DMMVici%20VC8145%20UK.html
Read conclusions carefully to avoid surprises.
Offline bdunham7
« Reply #16 on: April 12, 2023, 03:29:51 am »
Actually the 'basic' features it has--REL, MIN/MAX and AUTOHOLD may be more useful generally than the extended DMM features that define a 'sophisticated' meter.   And some of those lack these basics or they don't work as well.
Offline Fungus
« Reply #17 on: April 12, 2023, 03:45:45 am »
Yes, but no capacitance, no frequency... etc.
It's true that those measurements are less common and an LCR meter is better for capacitance, an oscilloscope is better for frequency.
The Fluke 27 is a good option for leaving on all day long and taking basic measurements so long as you have other meters for the "sophisticated" stuff.
Offline armandine2
« Reply #18 on: April 12, 2023, 11:55:37 am »
this is one I hadn't seen before - no idea if it fits your needs
In a closed society where everybody's guilty, the only crime is getting caught - Hunter S Thompson
Offline Fungus
« Reply #19 on: April 12, 2023, 01:47:42 pm »
Why not start a new thread about it?
Offline armandine2
« Reply #20 on: April 12, 2023, 02:17:39 pm »
 Am I the only one that think some rechargeable cell is a good idea ?
may be not
Offline Fungus
« Reply #21 on: April 12, 2023, 02:31:35 pm »
This one doesn't turn off and the battery will last for thousands of hours:
https://www.eevblog.com/forum/testgear/trashy-meters-redux/
But you don't say what sort of things you want to measure. What safety do you need?
Offline mwb1100
« Reply #22 on: April 12, 2023, 06:00:04 pm »
The first post said that he's concerned about being startled by the APO warning beeps from the meter when he has "hands stuck inside high voltage equipment, not the most ideal time to beep and make me jump...".  I interpreted this as a safe meter would be desired.  However, the OP does goes on to ask whether using a "cheap ebay meters and a 5v mobile power adapter" would work, but mentions concerns about the "risk of shock if the cheap china mobile chargers break down".
All this made me avoid suggesting meters that have dodgy input protection and questionable safety (hence the Fluke & Brymen suggestions).
I might have suggested the Uni-T UT161 series (a variant of the UT61+ series with improved input protection) but I'm not sure how close those meters might be to Fluke/Brymen level of safety.
« Last Edit: April 12, 2023, 06:10:11 pm by mwb1100 »
Offline Fungus
« Reply #23 on: April 12, 2023, 06:11:07 pm »
The first post said that he's concerned about being startled by the APO warning beeps from the meter when he has "hands stuck inside high voltage equipment, not the most ideal time to beep and make me jump...".  I interpreted this as a safe meter would be desired.  ... hence the Fluke & Brymen suggestions.
He also said "...not bankrupt me or cost an amount that will never make me dare use it"   :-//
Maybe some ear plugs could solve the problem?
Offline Fungus
« Reply #24 on: April 12, 2023, 06:12:47 pm »
I think we need a lot more info about what needs measuring and what meters OP already owns.
