Author Topic: BK2190E Oscilloscope Stay in the on screen.  (Read 3744 times)
Re: BK2190E Oscilloscope Stay in the on screen.
« Reply #25 on: October 13, 2024, 09:38:13 pm »
Good day! I turned on my 2190E for the first time in around 6 months and found it hung on the boot screen like others noted. I used the flash drive method with the recovery files, and now it moves past the boot screen, but none of the buttons or dials are working, nor will it display any activity on channels 1 or 2.
Strangely, it does recognize when a USB device is removed or inserted; it makes a sound and the notification appears on the screen.
Any ideas on what could work? I’ve tried the Math button approach, and a few different flash drives formatted to FAT32 with 4k clusters, ranging from 1GB to 2GB in size.
Welcome to the forum.
Exactly what flash drive method and from where/whom ?
Offline bpottle
« Reply #26 on: October 13, 2024, 10:43:53 pm »
Hi Tautech,
On one of the posts was a link to the .zip file entitled “2190E_recovery_by_USB_driver”; I downloaded this and followed the pdf’s instructions included in the .zip file, and further followed your suggestions in the comments (on trying different USB drives 8GB or under).
Thank you!
Brian
« Reply #27 on: October 13, 2024, 10:57:29 pm »
Hi Tautech,
Thank you!
Brian
Which on further investigation is different to what I have here.
Taken to PM
