As the number of posts increases, it is possible that the others may not have a comprehensive understanding of all the feedback issues. Therefore, I have compiled a summary of these issues.
The bugs should be easy to solve, but some wanted features are not easy to implement.
If there are any new bugs or wanted features in the future, I will update here.
What is not fully confirmed is using an orange background.
Bugs: Split to another thread
https://www.eevblog.com/forum/testgear/sds800x-hd-bug-reports-firmware/Top 10 Wanted Features or Improvement( No more than 10, Currently 7 ): 4.
new feature - Pressing the autosetup button does not require confirmation and provides a configurable menu.Have option to revert last autosetup to the settings before. -- RAPo
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5399027/#msg5399027Reason: More than one person mentioned that they don't like the confirmation.
19.
new feature - UART support show the entire "message" as a single frame/packet. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457443/#msg5457443Reason: Good function, can be observed through packet data, can refer to RTB2000.
24. improvement - When using the knob with cursors, the cursor menu opens when pushing the knob. This is totally unnessary. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5414138/#msg5414138
Reason: Continuously popping up menus affects observation. When the menu is embedded, it will cause the mouse position to shift.
Note: Resolved in 1.1.3.6. 33.
new feature - There is a way to export measure track window data ? -- markone
https://www.eevblog.com/forum/testgear/sds800x-hd-featureimprovment-disscusions/msg5454929/#msg5454929Reason: The data should be able to be exported for easy subsequent analysis.
34.
new feature - When long click on the measurement table, activate its measurement cursors. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457125/#msg5457125Reason: A practical feature that enhances efficiency.
35.
new feature - Displaying the waveform update rate. -- Martin
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5456924/#msg5456924Reason: No need to connect to trigout to know the current capture rate.
36.
new feature - Bit rate measurement. -- AndyC_772
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457524/#msg5457524Reason: This feature is very useful. I often use the cursor to determine the bit rate, which is inconvenient.
37.
improvement - Navigation save menu settings. -- ebastler
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457761/#msg5457761Reason: Save menu configuration to allow users to set fewer parameters.
Wanted Features: 1.
new feature - Support custom channel colors. -- Martin
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5381963/#msg53819632.
new feature - Support fine adjustment for the timebase. -- Anthocyanina
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5382683/#msg53826833.
new feature - Support simultaneous viewing of xy and yt waveforms. -- RAPo
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5389370/#msg53893704.
new feature - Pressing the autosetup button does not require confirmation and provides a configurable menu. -- RAPo
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5399027/#msg53990275. improvement - Move the channel invert between the probe and the label. -- RAPo
Note: Different people have different usage habits, so it is difficult to define which one is more commonly used. Remove this requirement first.6. improvement - The Save button under the Bode Plot does not work. Modify it to save the image according to the Bode Plot print settings. -- tszaboo
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5399735/#msg5399735
Note: Resolved in 1.1.3.6. 7.
new feature - UI supports setting hostname and domain. -- newbrain
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5401697/#msg54016978.
improvement - Click the physical button to move forward and backward. When operating the history frame, only one frame will be changed. If long pressed, it will accelerate. -- newbrain
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5401697/#msg54016979.
improvement - The position of the mouse on the list can also be changed by using the scroll wheel to change the current frame. -- ebastler
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5424557/#msg542455710.
improvement - Changing the scroll wheel on the scrollbar should also change the current frame. -- ebastler
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5424557/#msg542455711.
new feature - In decode mode export all the frames in a waveform, even if there ist a frame limit. -- eTobey
https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/msg5410070/#msg541007012. When the decode frame limit is exceeded, it is possible to automatically change the horizontal position, re decoding, and search for the desired result. -- eTobey
Note: After the implementation of Wanted Feature No.17, this function is not necessary13.
new feature - Control different external siglent sdg. -- Bad_Driver
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5408471/#msg540847114.
new feature - Copy the math channel to another math channel. -- Bad_Driver
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5408471/#msg540847115.
new feature - Math operator supports measuring parameters. -- Bad_Driver
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5408471/#msg540847116.
improvement - The data sheet needs to add a decoding maximum frame limit. -- Martin
https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/msg5409962/#msg540996217.
new feature - Wildcards in the equality condition for serial ID and/or Data triggers, like it is already implemented for SPI.
Wildcards for every position, and not the first two bytes of the data.Could be extended to having a NOT negation (with wildcards too). -- eTobey
https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/msg5407148/#msg540714818.
new feature - Wake on LAN. (There is an alternative solution, using a "Auto Power On" function and a WiFi power socket.) -- newbrain
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5412014/#msg541201419.
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5412314/#msg5412314https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457443/#msg545744320.
improvement - Choose a file to overwrite in the file manager. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5412071/#msg541207121.
improvement - Add some commonly used characters to the keyboard letter page so that there is no need to switch. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5412071/#msg541207122.
new feature - Roll mode supports decoding after stop. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5413484/#msg541348423.
new feature - Quick Button supports more features, such as saving images. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5413772/#msg541377224. improvement - When using the knob with cursors, the cursor menu opens when pushing the knob. This is totally unnessary. -- eTobey
Note: Resolved in 1.1.3.6. 25. improvement - When typing with the keyboard, dont close everything, when you click on a non keyboard area. Solution: have a margin around the keyboard. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5414924/#msg5414924
Note: Resolved in 1.1.3.6. 26.
improvement - The save/recall and save button functions interact with each other, the save type for the save button will then not be changed by the save/recall menu. -- Martin
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5383955/#msg538395527.
new feature - Decoding supports multiple display formats simultaneously.Another solution: Make quick button cycle through hex, dec, binary, ASCII. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5425883/#msg542588328.
new feature - Trigger parameters synchronization to other trigger types. Providing personalized settings. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5439797/#msg5439797https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5432240/#msg5432240https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5439890/#msg543989029.
improvement - optimize input pad. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5441396/#msg5441396https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5441618/#msg544161830. improvement - The checkbox for percent and count in the histogram window are to small, and easily missed. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5452967/#msg5452967
Note: Resolved in 1.1.3.6. 31.
improvement - Mask Test add a line with the current running status. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5453378/#msg545337832.
new feature - There is a way to "embed" the small floating measure track window in the main display like a math trace ? -- markone
https://www.eevblog.com/forum/testgear/sds800x-hd-featureimprovment-disscusions/msg5454929/#msg545492933.
https://www.eevblog.com/forum/testgear/sds800x-hd-featureimprovment-disscusions/msg5454929/#msg545492934.
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457125/#msg545712535.
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5456924/#msg545692436.
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457524/#msg545752437.
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457761/#msg545776138.
improvement - Remove redundant digits in axis labels. -- ebastler
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457677/#msg545767739.
new feature - Siglent DSOs that support Bode Plots and Math Functions would be to allow the DUT Input and Output selections to support not only Channels 1-4 but also the Math Function -- mawyatt
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5466451/#msg546645140.
improvement - Clicking on SIGLENT will restart waveform acquisition, which occasionally causes errors when clicking on analysis, resulting in the loss of data collected for a long time. -- eTobey
Version download:https://siglentna.com/service-and-support/firmware-software/digital-oscilloscopes/#sds800x-hd-seriesSDS800X HD Firmware_V1.1.3.3 (Release Date 03.04.24 )
SDS800X HD Firmware_V1.1.3.6 (Release Date 05.23.24 ) (At least 14 bugs and 4 improvements have been merged, based on eevblog)
Latest developments:
