Author Topic: SDS800X HD Wanted Features  (Read 539787 times)
0 Members and 27 Guests are viewing this topic.
Online KungFuJosh
  • TEAS is real.
Re: SDS800X HD Bugs/Wanted Feat
« Reply #25 on: March 23, 2024, 08:50:04 pm »
I played with Bode plots with my SDG2122 (born as 2042) and it works very well via IP network.
But it would be nice to control the Sig Gen also for „simple“ tasks like a internal Gen of the SDS2000x+ (as example) from the scope.
That's a fun idea. They could add an option in the settings to define which AWG you're controlling and whether you want to control an internal or external AWG. Set the IP, and go. The scopes are already capable of remote control, so now it's a matter of adding manual control of the external device. Shouldn't be too hard to do, but whether they'd do it or not is a different story.
Online Martin72Topic starter
  • Testfield Technician
Re: SDS800X HD Bugs/Wanted Features
« Reply #26 on: March 23, 2024, 09:01:27 pm »
Like my idea a few years ago when I had the 2000Xplus.
And that was to decode infrared remote control signals.
After all, Siglent EU support politely asked me what it could be used for. ;)
(Kierkegaard)
« Reply #27 on: March 23, 2024, 09:29:45 pm »
If they had done it, Siglent would have been the only brand.
But who cares about remote control signals except me. 8)
(Kierkegaard)
The following users thanked this post: Mortymore, KungFuJosh, Bad_Driver
Offline electronics hobbyist
  • Country: cn
    • sds800x-hd-review-demonstration-thread
« Reply #28 on: March 24, 2024, 08:15:03 am »
My wish list:
- control of an external SDG Siglent Generator via scope UI, not only for Bode plots and with SAG1021
I can think of the benefit of controlling through the oscilloscope UI, which is that it is easier to control through a large touch screen, but this feature is not easy to implement because there are various models of external signal sources. If you want to fully support all the functions of all signal sources, it is equivalent to rewriting the UI of multiple signal sources, which will be a very large workload, and most people have their signal source right beside them, which can be directly controlled. If only a few simple signal output types are supported, then this feature is relatively easy to implement.
- copy F-channel settings to another F-channel
Agree, this is a good requirement.
- math operations with numerical measurements (Vpp(ch1)/Vpp(ch2) as example)
What are the specific application scenarios of this feature and what problems can it solve? Vpp (ch1)/Vpp (ch2) are just ratios, isolated points without units
« Last Edit: March 24, 2024, 08:35:52 am by electronics hobbyist »
The following users thanked this post: rf-loop
Online 2N3055
  • Country: hr
« Reply #29 on: March 24, 2024, 10:29:04 am »
Controlling full standalone generator from scope screen is not very practical or useful idea.
You already have full user interface on the gen, buttons knobs and all.
Mostly used scenario is that you tweak something on a AWG and simultaneously watch the scope for changes  in signal, tweaking scope setting along the way.
You cannot do that on same screen at the same tome...
Offline Bad_Driver
« Reply #30 on: March 24, 2024, 11:08:56 am »
It depends on your setting. My Gen is on the shelf above my bench where my SDS sits. Eyes on the screen, one hand on the probe, other hand on the mouse.
Some Siglent SDS have an inbuilt gen as my SDS2000x+. Why not open the existing functionality (also the SDS800 has it) for external Gens?
And to make it clear, I request only base functionality.
Offline Bad_Driver
« Reply #31 on: March 24, 2024, 11:13:57 am »
As an example: A simple dB calculation of  Vpp of two channel's (20*log(Vpp(ch2)/Vpp(ch1)))
Online 2N3055
  • Country: hr
« Reply #32 on: March 24, 2024, 11:17:36 am »
Don't get me wrong.
I don't mind if they add this.
I'm just saying that for me I would not use it and explained how and why. Sort of like a vote. From me : I don't need it. Rest of you do your thing. Live and let live.
Offline gf
« Reply #33 on: March 24, 2024, 11:39:10 am »
Still, it would be just a scalar number while the existing Math functions deal with time series, right? Seems like a new category of math -- "math on measurements" or "derived measurements" or such. I am not sure where it should reside in the UI, and whether adding that new category to the UI is worthwhile for the benefit it gives.
IMO, a scalar result should be displayed like other measurements (mean, max, min, histogram,...).
OTOH, an expression like CH1/max(CH1) would still be a function of time, i.e. a math trace.
« Last Edit: March 24, 2024, 11:49:05 am by gf »
The following users thanked this post: ebastler, newbrain
  • Country: cn
« Reply #34 on: March 24, 2024, 11:55:36 am »
If all other users are like you, just support simple types, this requirement is easy.
But once it is supported, the requirements will continue to come from different customers. For manufacturers, the cost-effectiveness is very low.
« Last Edit: March 24, 2024, 12:03:00 pm by electronics hobbyist »
Online 2N3055
  • Country: hr
« Reply #35 on: March 24, 2024, 12:51:19 pm »
It is not that simple.
Some measurements are multi measurements (thousands of measurements in single trace, one for each period) and some are for whole captured record (like P-P).
Mixing measurements into math channels is not trivially possible as it is.
Creating a separate math formula entry for measurements might be, but here measurements are also mixed scalar and one dimension matrix depending on type. That would need to be sorted out.
Offline Bad_Driver
« Reply #36 on: March 24, 2024, 02:40:54 pm »
Since my experience with modern high end scopes is limited to my two Siglent scopes I have no idea if this kind of „scalar math“ is available on other brands?
The best scope I had in my lab during my University time was a russian 50 MHz scope…. long time ago. Now for me this is all about hobby and learning.
Online 2N3055
  • Country: hr
« Reply #37 on: March 24, 2024, 03:11:16 pm »
Some high end LeCroy scopes have Custom measurements, but that is basically API for user scripts in several languages..
So you can, for instance, use custom MATLAB function to calculate something.
No such thing as direct integration like it is discussed here.
The following users thanked this post: Bad_Driver
  • Country: cn
« Reply #38 on: March 25, 2024, 02:54:23 am »
As the number of posts increases, it is possible that the others may not have a comprehensive understanding of all the feedback issues. Therefore, I have compiled a summary of these issues.
The bugs should be easy to solve, but some wanted features are not easy to implement.
If there are any new bugs or wanted features in the future, I will update here.
What is not fully confirmed is using an orange background.
Bugs: Split to another thread
https://www.eevblog.com/forum/testgear/sds800x-hd-bug-reports-firmware/
Top 10 Wanted Features or Improvement( No more than 10, Currently 7 ):
4. new feature - Pressing the autosetup button does not require confirmation and provides a configurable menu.Have option to revert last autosetup to the settings before.  --  RAPo
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5399027/#msg5399027
Reason: More than one person mentioned that they don't like the confirmation.
19. new feature - UART support show the entire "message" as a single frame/packet.  -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457443/#msg5457443
Reason: Good function, can be observed through packet data, can refer to RTB2000.
24. improvement - When using the knob with cursors, the cursor menu opens when pushing the knob. This is totally unnessary.  -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5414138/#msg5414138
Reason: Continuously popping up menus affects observation. When the menu is embedded, it will cause the mouse position to shift.
Note: Resolved in 1.1.3.6.
33. new feature - There is a way to export measure track window data ?  -- markone
https://www.eevblog.com/forum/testgear/sds800x-hd-featureimprovment-disscusions/msg5454929/#msg5454929
Reason: The data should be able to be exported for easy subsequent analysis.
34. new feature - When long click on the measurement table, activate its measurement cursors.  --  eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457125/#msg5457125
Reason: A practical feature that enhances efficiency.
35. new feature - Displaying the waveform update rate. --  Martin
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5456924/#msg5456924
Reason: No need to connect to trigout to know the current capture rate.
36. new feature - Bit rate measurement. -- AndyC_772
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457524/#msg5457524
Reason: This feature is very useful. I often use the cursor to determine the bit rate, which is inconvenient.
37. improvement - Navigation save menu settings. -- ebastler
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457761/#msg5457761
Reason: Save menu configuration to allow users to set fewer parameters.
Wanted Features:
1. new feature - Support custom channel colors. -- Martin
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5381963/#msg5381963
2. new feature - Support fine adjustment for the timebase. -- Anthocyanina
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5382683/#msg5382683
3. new feature -  Support simultaneous viewing of xy and yt waveforms. --  RAPo
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5389370/#msg5389370
4. new feature - Pressing the autosetup button does not require confirmation and provides a configurable menu.  --  RAPo
5. improvement - Move the channel invert between the probe and the label.  --  RAPo
Note: Different people have different usage habits, so it is difficult to define which one is more commonly used. Remove this requirement first.
6. improvement - The Save button under the Bode Plot does not work. Modify it to save the image according to the Bode Plot print settings. -- tszaboo
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5399735/#msg5399735
7. new feature - UI supports setting hostname and domain. -- newbrain
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5401697/#msg5401697
8. improvement - Click the physical button to move forward and backward. When operating the history frame, only one frame will be changed. If long pressed, it will accelerate. -- newbrain
9. improvement - The position of the mouse on the list can also be changed by using the scroll wheel to change the current frame.   -- ebastler
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5424557/#msg5424557
10. improvement - Changing the scroll wheel on the scrollbar should also change the current frame.   -- ebastler
11. new feature - In decode mode export all the frames in a waveform, even if there ist a frame limit.  -- eTobey
https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/msg5410070/#msg5410070
12. When the decode frame limit is exceeded, it is possible to automatically change the horizontal position, re decoding, and search for the desired result.  -- eTobey
Note: After the implementation of Wanted Feature No.17, this function is not necessary
13. new feature - Control different external siglent sdg. -- Bad_Driver
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5408471/#msg5408471
14. new feature - Copy the math channel to another math channel. -- Bad_Driver
15. new feature - Math operator supports measuring parameters. -- Bad_Driver
16. improvement - The data sheet needs to add a decoding maximum frame limit.  -- Martin
https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/msg5409962/#msg5409962
17. new feature - Wildcards in the equality condition for serial ID and/or Data triggers, like it is already implemented for SPI.
Wildcards for every position, and not the first two bytes of the data.Could be extended to having a NOT negation (with wildcards too).  -- eTobey
https://www.eevblog.com/forum/testgear/siglent-sds800x-hd-12-bit-dsos-coming/msg5407148/#msg5407148
18. new feature - Wake on LAN. (There is an alternative solution, using a "Auto Power On" function and a WiFi power socket.) -- newbrain
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5412014/#msg5412014
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5412314/#msg5412314
20. improvement - Choose a file to overwrite in the file manager.  -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5412071/#msg5412071
21. improvement - Add some commonly used characters to the keyboard letter page so that there is no need to switch.  -- eTobey
22. new feature - Roll mode supports decoding after stop.  -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5413484/#msg5413484
23. new feature - Quick Button supports more features, such as saving images.  -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5413772/#msg5413772
25. improvement - When typing with the keyboard, dont close everything, when you click on a non keyboard area. Solution: have a margin around the keyboard. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5414924/#msg5414924
26. improvement - The save/recall and save button functions interact with each other, the save type for the save button will then not be changed by the save/recall menu. -- Martin
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5383955/#msg5383955
27. new feature -  Decoding supports multiple display formats simultaneously.Another solution: Make quick button cycle through hex, dec, binary, ASCII. -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5425883/#msg5425883
28. new feature -  Trigger parameters synchronization to other trigger types. Providing personalized settings.  -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5439797/#msg5439797
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5432240/#msg5432240
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5439890/#msg5439890
29. improvement - optimize input pad.  -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5441396/#msg5441396
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5441618/#msg5441618
30. improvement - The checkbox for percent and count in the histogram window are to small, and easily missed.  -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5452967/#msg5452967
31. improvement - Mask Test add a line with the current running status.  -- eTobey
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5453378/#msg5453378
32. new feature -  There is a way to "embed" the small floating measure track window in the main display like a math trace ? -- markone
38. improvement - Remove redundant digits in axis labels. -- ebastler
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5457677/#msg5457677
39. new feature - Siglent DSOs that support Bode Plots and Math Functions would be to allow the DUT Input and Output selections to support not only Channels 1-4 but also the Math Function -- mawyatt
https://www.eevblog.com/forum/testgear/sds800x-hd-bugswanted-features/msg5466451/#msg5466451
40. improvement - Clicking on SIGLENT will restart waveform acquisition, which occasionally causes errors when clicking on analysis, resulting in the loss of data collected for a long time. --  eTobey
Version download:
https://siglentna.com/service-and-support/firmware-software/digital-oscilloscopes/#sds800x-hd-series
SDS800X HD Firmware_V1.1.3.3 (Release Date 03.04.24 )
SDS800X HD Firmware_V1.1.3.6 (Release Date 05.23.24 ) (At least 14 bugs and 4 improvements have been merged, based on eevblog)
Latest developments:
« Last Edit: May 27, 2024, 01:53:24 am by electronics hobbyist »
The following users thanked this post: rf-loop, Performa01, AndyC_772, ebastler, newbrain, Mortymore, Martin72, Bad_Driver, eTobey
« Reply #39 on: March 25, 2024, 06:44:14 am »
(Kierkegaard)
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #40 on: March 25, 2024, 07:00:17 am »
OK, now I want one of those adaptors.... did you make it?
Cheers Scott
« Reply #41 on: March 25, 2024, 08:36:01 am »
I received the adapter as a gift from my boss at the time, it looks like a purchased part.
But you can also build it yourself:
http://www.afug-info.de/Schaltungen-Eigenbau/IR-Tester/
(Kierkegaard)
Offline newbrain
« Reply #42 on: March 25, 2024, 12:23:05 pm »
Thanks for the summary!
The bugs should be easy to solve, but some requirements are not easy to implement.
If there are any new bugs or requirements in the future, I will update here.
Bugs:
1. After saving the reference waveform, clicking the save button will restore it to png type.
2. Some parameters have not been restored after selfcal, such as fft vertical gear, fft markers, and channel vertical settings.
3. After restarting, the vertical gear of FFT did not restored.
4. There have been crashes when using CAN and IIC decoding.The probability of reproduction is relatively low.
5. The universal knob can only set the history frame when opening the menu, and should be able to operate the list when closing the menu.
6. When the menu disappears, the universal knob light is still on, and at this time, the universal knob is used to change the brightness of the waveform.
Requirements:
1. Support custom channel colors.
2. Support fine adjustment for the timebase.
3. Support simultaneous viewing of xy and yt waveforms.
4. Pressing the autosetup button does not require confirmation and provides a configurable menu.
5. Move the channel invert between the probe and the label.
6. The Save button under the Bode Plot does not work. Modify it to save the image according to the Bode Plot print settings.
7. UI supports setting hostname and domain.
8. Click the physical button to move forward and backward. When operating the history frame, only one frame will be changed. If long pressed, it will accelerate.
9. The position of the mouse on the list can also be changed by using the scroll wheel to change the current frame.
10. Changing the scroll wheel on the scrollbar should also change the current frame.
11. When the decode frame limit is exceeded, the decoding result of saving the complete data frame can be achieved by automatically changing the horizontal position, re decoding, and saving.
13. Control different external siglent sdg.
14. Copy the math channel to another math channel.
15. Math operator supports measuring parameters.
16. The data sheet needs to add a decoding maximum frame limit.
17. Wildcards in the equality condition for serial ID and/or Data triggers, like it is already implemented for SPI.
I would add one thing to the network related desires:
    Add Wake on LAN (magic packet, nothing fancier).
After all, with 4 W power consumption in standby, it might be awake enough to handle that.
(might or might not be at possible depending on the used NIC, though).
PS: this comes from a very self serving opportunity, I've been mobility challenged by a broken leg, so I had set up the scope and a DUT to have some fun from bed.
I could control the DUT via PC (used in remote access), same for the home built PSU, and obviously the VNC connected scope but I still had to go to the bench to turn it on !
  • Country: cn
« Reply #43 on: March 25, 2024, 12:40:14 pm »
I'm sorry to hear that. This is a reasonable requirement for you. Let me add it first. This function may not be possible, but there is an alternative solution. The oscilloscope has a "Auto Power On" function, opening this function, and you need a WiFi power socket. By opening the power socket through WiFi, the oscilloscope can be opened.The WiFi power socket costs a few dollars approximately in china.
« Last Edit: March 26, 2024, 09:34:29 am by electronics hobbyist »
Offline eTobey
« Reply #44 on: March 25, 2024, 12:57:00 pm »
You can add to no. 5 and no.6:
When operating history, and measuring with cursers, history is changed simultaneously.
Requirement No. 11, is how it works currently, but should be changed to be used in export automatically (For the whole captured waveform).
Requirement No. 12 is the same?
Requirement No. 17: Wildcards for every position, and not the first two bytes of the data.
Another thing i found (corrent me if i am wrong):
The save button should remember what i want to save.
The quick button is not really quick for saving a screenshot.
More:
The scrollbar is very thin in the filemanager.
I can not simply choose a file to overwrite. (Thats a real bad one to miss in my opinion)
The keyboard has no spacebar. And the screen would be big enough, to show more or even all buttons of it.
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant." (Maxim Gorki)
  • Country: cn
« Reply #45 on: March 25, 2024, 01:04:59 pm »
More:
 :-+ Thank you, I will check each one tomorrow.
Offline newbrain
« Reply #46 on: March 25, 2024, 01:26:57 pm »
Thanks for the consideration and support!
But no worries, I'm out of the cast since three of days, and "quickly" recovering (walked 1.5 km yesterday, instead of my usual 20) - that was just what sparked the request.
Offline eTobey
« Reply #47 on: March 25, 2024, 01:56:14 pm »
I got that one wrong: "The save button should remember what i want to save."
For example, if i setup "save jpg", for the "save button", and then i just saved the settings with the menu, i dont want to change the save button. I want to assign a "save type" just like for the quick button. ("save jpg" for the quick button is not quick/useful, as it only opens the menu for saving jpg ).
Offline eTobey
« Reply #48 on: March 25, 2024, 03:15:46 pm »
Tried to use the uart decode feature... Not really helpful in my case...
(Yes the picture shows CAN, but its about how it could be done better, and this applies to other decode protocolls too.)
« Last Edit: April 15, 2024, 05:48:18 am by eTobey »
Offline tautech
« Reply #49 on: March 25, 2024, 08:54:20 pm »
I'm sorry to hear that. This is a reasonable requirement for you. Let me add it first. This function may not be possible, but there is an alternative solution. The oscilloscope has a "power on line" function, opening this function, and you need a WiFi socket. By opening the socket through WiFi, the oscilloscope can be opened.The WiFi socket costs a few dollars approximately in china.
SDS800X HD does not support a WiFi dongle, only WiFi access is via a mini WiFi AP router configured in Bridge mode to access local WiFi access points.
TP Link TL-WR802N is the one I current use.
We hope Siglent will reevaluate their decision not to have 800X HD support WiFi and instead offer the convenience of WiFi connectivity like SDS2000X-E, SDS12/1104X-E has.  :popcorn:
« Last Edit: March 25, 2024, 09:33:39 pm by tautech »
