Author Topic: New Sigrok/PulseView hardware support (Siglent SDS HD, Rigol DHO800...)  (Read 5678 times)
Offline Spike
Re: New Sigrok/PulseView hardware support (Siglent SDS HD, Rigol DHO800...)
« Reply #50 on: August 03, 2024, 12:29:42 am »
Any chance this could be merged to master?
Done !
@Spike if you have working Mac build, maybe you could share it here ?
Sure, here's something:
https://www.dropbox.com/scl/fo/7fp3toladqj5fz16ugp8w/AImd1yuWyACIZ1nnTrm9-rk?rlkey=be64qo1o3ppvu24sbm05s8rxu&dl=0
The dmg doesn't explicitly say it but the arm64 will only run on Sonoma and the x86_64 is for Ventura.
The following users thanked this post: kripton2035, fredo_
Offline fredo_Topic starter
« Reply #51 on: August 03, 2024, 11:31:47 am »
You can find the log result of few unsuccessful attempt below.
Thanks for that Frex! I just sent you a PM to investigate your problem.
Great ! I'll add the link to OP if it's OK for you.
Have you been able to test this Mac version with your scope ?
Offline Spike
« Reply #52 on: August 03, 2024, 04:34:37 pm »
Nope.  I just learned that my scope will be delayed a further 6 weeks; I won’t see it until mid-September.  I’ve been providing these builds to kripton2035 from this thread, and rosenrot who reached out to me privately.  You’d have to ask them if there are issues.
« Last Edit: August 03, 2024, 04:38:20 pm by Spike »
The following users thanked this post: fredo_
Online Furna
« Reply #53 on: August 04, 2024, 12:07:34 pm »
Hi guys,
I just updated the patch with the following changes:
07/27/2024 Update
Siglent SDS :
- Fixed acquisition for memory depth > 4 Mpts
Working OK on SDS8024X HD
2330199-0
2330203-1
Also multi channel acquisition is working
2330207-2
2330211-3
« Last Edit: August 04, 2024, 12:24:59 pm by Furna »
The sky above the port was the color of television, tuned to a dead channel.
Offline kripton2035
« Reply #54 on: August 04, 2024, 12:51:38 pm »
seems to work fine on the arm/sonoma version for me. even a 100Mpts acquisition seems to work, but it takes a long time to come to the computer (20-30s)
Offline kripton2035
« Reply #55 on: August 04, 2024, 12:57:09 pm »
it also seems to work with a 200Mpts acquisition...
« Reply #56 on: August 04, 2024, 10:08:09 pm »
Thank you @Furna and @kripton2035 for the feedback, glad to know that it starts working ! :)
Quote from: kripton2035 link=topic=432887.msg5593343#msg5593343 date=1722775 reached out to me privately.  You’d have to ask them if there are issues.[/quote
That's perfectly normal : there is a huge amount of data to transfer over TCP (that's 100Mbyte per channel), it takes quite some time.
Anyone with a Rigol DHO800 or 900 was able to play with it ?
I created a new version to try and solve triggering issues on large time bases :  Windows (64bits) installer (zip password is 'sigrok').
08/04/2024 Update
Siglent SDS :
- Fixed triggering issues on large timebases
- Known limitations :
   - USB acquisition does not work (use TCP/IP with Raw TCP and port 5025)
   - LA acquisition pagination (for memory depth > 5Mpts) is not working on SDS 2000X HD (firmware issue ?) causing the first 5Mpts to be replicated several times
   - LA acquisition might fail for memory depth > 50 Mpts
I worked with @Frex too to fix support for SDS 2000X Plus and he reported that he managed a 100Mpts acquisition on 4 analog channels + 16 digital channels !
Please keep the feedback coming! :popcorn:
« Last Edit: August 04, 2024, 10:10:42 pm by fredo_ »
Offline skander36
« Reply #57 on: August 04, 2024, 10:44:41 pm »
It seem to work also with SDS1000X-HD.
I can't connect to DHO1000X-HD.
« Reply #58 on: August 04, 2024, 11:06:45 pm »
Great, thank you for the feedback @skander36 !
That's because I only added DHO800/900 to the driver descriptor.
If DHO1000 line uses the same SCPI protocol, I can try and add it too.
For that I would need :
- The response to the "*IDN?" SCPI command
- For USB support, the productId as returned by lsusb or equivalent (see here)
Offline skander36
« Reply #59 on: August 05, 2024, 09:05:04 am »
Thank you very much for your work.
RIGOL TECHNOLOGIES,DHO1074,HDO1B244401552,00.02.13
For USB I will provide later as this scope use a high speed USB3) connector for which I dont have a cable -
Anyway I'm not using USB for any device.
« Reply #60 on: August 05, 2024, 01:57:41 pm »
Regarding LA acquisition, I spent quite some time trying and understand how to have pagination work (data blocks are limited to 5Mpts, over that memory depth, data has to be paginated) but I came to the conclusion that the SDS2000X HD has a bug that prevents pagination to work. The result is that the first 5Mpts datablock is replicated several times on LA channels :-/
I ended up sending a mail to Siglent support to report the issue. Not sure if/when I'll get a response and this will be fixed...
Just a quick update on this , I got the following  reply from Siglent support :
This may be a bug in the software. Our R&D department is analyzing this problem. I will inform you as soon as I have the result.
Wait and see !...
The following users thanked this post: KungFuJosh, Furna
Offline skander36
« Reply #61 on: August 07, 2024, 11:59:56 am »
SCPI - USB0::0x1AB1::0x0610::HDO1B244401552::INSTR
LSUSB - Bus 002 Device 006: ID 1ab1:0610 Rigol Technologies HDO1074
Windows Device Manager - USB\VID_1AB1&PID_0610\HDO1B244401552
The following users thanked this post: egonotto, fredo_
« Reply #62 on: August 07, 2024, 03:48:16 pm »
Thanks @skander36  :-+
And here comes the version with DHO1000 and DHO4000 support ! : Windows (64bits) installer (zip password is 'sigrok').
@skander36 and @Frex can you check if it is working as expected with your DHO1000 ?
Offline Spike
« Reply #63 on: August 07, 2024, 09:07:28 pm »
Apologies if anyone is waiting for a Mac build.  I’ve been sick recently and am still recovering and hope to be back on my feet in the next couple days.  I will try to get updated builds out then.
The following users thanked this post: kripton2035, egonotto, fredo_
Offline thm_w
  • Non-expert
« Reply #64 on: August 08, 2024, 12:11:22 am »
Thank you fredo, working here for USB and ethernet.
For USB, usual sigrok routine:
- Run Zadig -> Options -> Show all devices. Select DHO1000, replace driver with WinUSB.
- USB 3 cable is not required.
« Last Edit: August 08, 2024, 12:14:52 am by thm_w »
« Reply #65 on: August 08, 2024, 07:39:36 am »
Thank you @thm_w, that's good news !  :clap:
Offline neodimio91
« Reply #66 on: August 08, 2024, 11:35:00 am »
@_fredo , I'm a sds2104x plus owner, everything seems to work perfectly with new updates, feel free to reach me for any testing !
The following users thanked this post: tautech, fredo_
« Reply #67 on: August 08, 2024, 10:09:15 pm »
Thanks for the feedback @neodimio91 !  :-+
Offline Spike
« Reply #68 on: August 08, 2024, 10:32:46 pm »
Updated Mac builds available at the link provided previously.
