Author Topic: Upgrading Mainboard in Lecroy DDA-3000 (aka WavePro 7300a?)  (Read 176583 times)
Offline evac
  • Country: pt
Re: Upgrading Mainboard in Lecroy DDA-3000 (aka WavePro 7300a?)
« Reply #750 on: September 05, 2023, 11:22:24 am »
Regarding fan replacement, I'm looking at Sanyo Denki 9RA1212H1001 which is slightly less powerful than the stock Panaflo (~14% less air flow and ~10% less static pressure) but 8.5dB less noise.
However, they are a bit expensive at €37.
I've seen people suggest Noctua NF-A14 iPPC3000 or Nidec DC1225CB6/B7 in the thread, but the Nidec models are not easy to find and I wanted to avoid an adapter for 140mm fans (also the Noctua is only 4dB less noise than stock Panaflo).
Has anyone used other fans and how did they work out for you in terms of temps?
Offline hpw
« Reply #751 on: September 06, 2023, 06:15:07 am »
Often the temperature are even not shown on the service GUI. So hard to compare.
I went with the Nuctua & required 3D printing adapters. It is less load but still as a load hoover and requires good cooling. Each old fan is about 1.5kg.
I addition I reduced the two aluminum plate sizes, so easier & faster to handle in case of front panel re movement (as clean-up & Encoders to replace). In addition the 5...7mm black foam have to be replaces as I used afterwords a softer one.
Anyway, the LeCroy DSO was not a masterpiece how to build an easy maintainable / service able gear. Almost the front bezel as a nightmare as requires replacement but 3D printing not able to get equal bezel color.
Happy tuning.
Offline RamboChen
  • Country: cn
« Reply #752 on: October 11, 2023, 07:29:50 am »
Hi, can you share your dsoxstream installer 8.5? Thanks!
Offline yr6610
  • Country: cn
« Reply #753 on: December 11, 2023, 06:02:30 am »
Hello, Converter
I am upgrading LeCroy waverunner 7100a now, can you tell me how to upgrade to 7300a? Thank you very much.
Offline mx46
« Reply #754 on: June 05, 2024, 01:40:01 pm »
I really love the Lecroy scope.
The DDA-5005 is awesome, however, only fixed 50Ohm input.
Simple hardware mod:
Bought a broken WP72000 :-DD
I'ts already up and running. Had a weird error where Win7k did not find a startup file. Cloned the HDD, now it works flawlessly.
How did you repair the 50ohm?
Offline dmderev
« Reply #755 on: July 02, 2024, 07:48:19 pm »
Hello, I followed the thread of reinstallation with original touch panel, and interestingly the driver does work with hidden COM3 port (not displayed by Windows). But the problem is that the touch point coordinates are inverted: whatever should be an upper left corner of the touch panel is generating the coordinate in the lower right corner; the movement of touch point down is displayed as moving up. I found that there is a swap of X/Y setting and it needs to be checked after installation. But I did not yet find how to invert coordinates. I guess that the radical solution is to swap panel wires, but it is unchanged hardware and I am assuming that it used to work correctly before.
Does anyone know if / where is the setting to mirror X and Y directions?
