Author Topic: Agilent 6612C "Opt 760" board  (Read 1139 times)
Offline gamalotTopic starter
  • Correct my English
    • Youtube
« on: November 21, 2023, 12:11:55 am »
Today I took my 6612C apart and did some cleaning. I also took some pictures for those who are curious about what the "Opt 760 Isolation and Reversal relays" board looks like.
The following users thanked this post: Kean, Stray Electron, guenthert, alm
Offline guenthert
Re: Agilent 6612C "Opt 760" board
« Reply #1 on: November 22, 2023, 11:17:49 am »
Iiuc, the 6612C (and 6632B) service manual refers to it as
"A6 5063-3434 1 Relay Board (Optional)".  Sadly, no further hints.
Is a schematic available?
The following users thanked this post: gamalot
    • Youtube
« Reply #2 on: November 22, 2023, 01:04:02 pm »
Yes, I just found it!  >:D
    • Youtube
« Reply #3 on: November 22, 2023, 01:13:02 pm »
It's hidden in the 6632B's service manual.
The following users thanked this post: Stray Electron, guenthert
Offline Swake
« Reply #4 on: November 24, 2023, 08:34:49 pm »
Links to the open source version of this board made by Bateau020 for 6632B power supplies (and some others):
https://www.eevblog.com/forum/testgear/agilent-6632b-binding-posts/msg4466458/#msg4466458
https://github.com/hb020/HP6632B_relay_board
Also front binding posts with additional sense and ground.
https://github.com/hb020/HP6632B_binding_post:
« Last Edit: November 24, 2023, 08:36:21 pm by Swake »
When it fits stop using the hammer
    • Youtube
« Reply #5 on: November 25, 2023, 01:47:10 am »
This design seems to have been simplified so that it is only compatible with 66xxB and will not work with 661xC.
    • Youtube
« Reply #6 on: November 29, 2023, 08:06:37 am »
I removed the two larger relays from the board to get more layout details under them, and I noticed that the silkscreen of the relays' outline actually covered part of the guard rings.  :-//
The following users thanked this post: guenthert
    • Youtube
« Reply #7 on: December 02, 2023, 07:06:11 am »
I have made some progress on opt-760 clone, schematic diagram, gerber files, and BOM are attached.
The following users thanked this post: Kean, guenthert
