@2n3055: My point is, as it shows using the given probes (using shortest connections) gives false results (overshoots) for fast clocks.
So using a 1GHz FET probe using shortest connection trusted me. Also the phase behavior about is an opened task. IMHO.
50E basic measurement is one task, using probes the second task... and so on.
As the Topic on the given PDF: "Siglent SDS2000X Plus Bandwidth Discussion"... is IMHO a starting point.
Home workers may have a limited/reduced requirements, so to deal on real digital world required BW and Phase behavior to consider.
Even Siglent with the new DSO 6K model and 1..2 GHz FET probes does not provide the required information how the probes performs.
While currently I am missing a clear advice about required DSO BW & probes to measure more or less exact overshoots.
Ok thank you for clarifications..
It seems that you have missed previous few topics (they were some time ago) where it was discussed exactly that.
If you want to look at signals that have 200 ps edges you need 4 GHz scope and corresponding active probe. That is only way you will get what you want: a pristine pulse response. Period
Any time signal has edge that is faster than the risetime of the scope one of two things will happen:
1.) if scope has strong AA filters and aggressively cuts of (lowpass filters) any frequency that is above Nyquist by 40 dB or more (for a 8 bit scope) and it will show perfectly shaped squarewave with no overshoots but completely wrong, without any high frequency content and edges that will be as fast as a scope and not in any relation to what signal edges are. It will be complete lie, but it will look pleasing because it will look perfect. Which is complete bullshit because original signal is not perfect and 1/3 of energy content from that signal is missing.
2.) You can have response like most modern digital scopes have. That one will try to show as much of frequency content they can. If you feed that one with a signal that has slower edge than scope has, it will show it nicely without overshoots. It will show the same as scope from 1. point. But if you feed it signal that has very fast edge (like here where we feed signal with 40ps risetime to scopes with nominal risetimes from 500-800ps, 10-15 times faster), scope will show overshoots. You say that is bad. I say it is not. It's great. Scope is having problems and is not hiding the fact.
Those peaks are
information that my edge is too fast for my scope and that I know scope is lying to me. Scope in point 1. will show clean edges without overshoot all the time, when I have nice signal and when I have too fast signal with many thing hidden inside. I wont know a difference ..
So with my digital scope, if I see that a signal has an edge that is 400 something ps (edge of what my 1GHz scopes can do) and I see overshoots, I know signal is too fast for my scope. If I see the signal has an edge that is 400 something ps and there are no overshoots, I know it is right there at the edge. And what I see is true. And if I see 500-600 ps edge and overshoots I know it is DUT, not a scope.
If I routinely want to look at 100 ps edges I need to buy 4GHz+ scope...
So much about that.
As for probing, that has been discussed even more times.
That is something that we all agree is a most important and most misunderstood topic in using scopes.
Most of the times quality of measurements is directly related to probing issues. And realities of it.
Many users don't understand that when you connect probe it becomes part of the circuit and changes it. Even active probes, just to a bit smaller extent (if you chose right probe for the job). As frequencies go up, it gets much, much worse.
There is no perfect probe or a scope. It is all about education and knowing your instrument. Both weak and strong points. And working around those.
