The software from R&S page contains only the Firmware that operates the equipment.Is there for sw upgrades only and will not function as as stand alone (with windows installation done before). This is because the firmware does not contains the drivers necessary to access the boards inside the instrument (the PCI acq. board is not recognized ) .So, i tried this option first, on a VM to take a peek on what the sw does and install also on the real device.Because no driver exist the application will get stuck.
This is the reason why i ask about the image because i exhausted all other options!
Thank's
