I can confirm that hiding the SSID does cause reconnection issues for the scope. However, I do not believe it is the scopes problem, but most likely the dongle itself. The dongle negotiates the connection purely under instruction from the scope, and the dongle will look for the SSID beacon from your router, if it can't see it, it won't connect.
Thanks for the confirmation (exactly what I was seeking!) and for the clarification of the role of the dongle. It makes sense; the dongle operates in response to the scope, and the scope feeds it the SSID and IP to use to make the connection. As the dongle doesn't "see" the SSID, it doesn't know better and doesn't connect, or loses the existing connection.
I also do not understand your obsession with hiding your SSID?
Not at all; more of an old habit. It was off for a long time, and I never had any issue with devices connecting, and maintaining connections with the SSID off, so the scope experience was new and I was wondering if it was abnormal.
As to your IP issue, have you reserved the IP address on your router? If you haven't and relying on just having it saved on your scope, you can have issues reconnecting once your original DHCP lease time expires (e.g. overnight) even if it by chance it just happens to come up with the same IP again.
That's probably what's happening.
I have not yet reserved the address. I believe reserving the address was mentioned by tautech earlier.
My use of the scope often involves long period of monitoring but it's not necessary for me to be watching the scope continuously. Using the web connection, I can have the scope display on the computer while also doing other work with the computer. Also, the scope is moved around somewhat, and being able to easily/automatically (re-)establish the WiFi connection, and access the scope from the computer location is a big advantage.
The responses have helped immensely. I now have not only answers to my questions, but also a much better understanding of things like WiFi connections and the use of the dongle, as well as the concept of the "lease". This is all very much appreciated.
If I wasn't clear before, and gave the impression I was obsessed with "my way", I sincerely apologize.
I've had the SSID on for a couple of days and the wifi connecting is working fine. I'll have to see how to reserve the IP address on the router, but would imagine it can be done -- another learning experience.
Thanks again!
