Author Topic: sds1104X-E Additional wifi adapters?  (Read 3957 times)
Offline timgilesTopic starter
  • Programmer, DB architect
« on: June 10, 2018, 11:03:01 am »
Hi all,
The latest firmware mentions support for additional wifi adapters - but not which ones. Anyone know?
Re: sds1104X-E Additional wifi adapters?
« Reply #1 on: June 10, 2018, 06:33:51 pm »
Hi all,
Sorry I don't however the original dongle specified is from TP-Link model TL‐WN725N Gold version.
It's widely available for less than $15.
If additional drivers are indeed installed in FW V6.1.25R2 just try any WiFi dongles you have already and the display will show when one it recognizes is connected to USB.
When I beta tested them the only one I had was from a Samsung TV and the DSO didn't recognize it so I popped into my local PC shop and got the TL‐WN725N Gold version for NZ$20.
I'll ask Siglent today about additional types supported so should have a reply in say 12 hrs.
« Reply #2 on: June 12, 2018, 03:32:14 am »
Hi all,
OK so the official word is 25R2 allows use of more types of TP-Link model TL‐WN725N, but it seems unfortunately no others.
The chrome/silver version of TL‐WN725N is more readily available and a bit cheaper than the gold version.
The following users thanked this post: Apofview
Offline toli
  • Country: il
« Reply #3 on: June 12, 2018, 05:25:09 am »
Just be make sure I understand this properly, no matter what WiFi adapted I get and where I get it, I would still need to purchase the WiFi software option (69$ IIRC) to be able to use it, even with the latest fw version, right?
My DIY blog (mostly electronics/stereo related):
http://tolisdiy.com/
« Reply #4 on: June 12, 2018, 07:08:47 am »
Correct and only once the free trial times expire but there is another WiFi solution if you want to follow the solution Bob Sava took:
https://www.eevblog.com/forum/testgear/cheap-wifi-for-sds1000x-e/
The WiFi dongle option is neat and tidy but Bob's solution might be equally fine for some users.
The following users thanked this post: toli, Apofview
