SDS1102CNL vs SDS1102CML
Could anyone say wich is the best and why please (if there is any relevant diference) ? ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Thanks in advance
The only relevant difference between these models is the memory depth, 40 Kpts vs 2Mpts.
For other than detailed examination of a captured waveform it is unlikly you will see much difference.
Both models have 1 Gsa/s sampling that is shared between both channels.
The Siglent DSO range has an advantange over most compeditors with 400 V channel input ratings.
This means more safety for your scope if the need arises to examine HV waveforms.
Errors in usage also have a larger margin of error without damaging the scope.
