I created this thread so that there was something specifically dedicated to "improving" the SDM3045X DMM.
For those of you that don't already know, the SDM3045X 4.5 digit hardware is identical to the Chinese version SDM3055X-E DMM. With a fairly simple firmware modification, you can improve your DMM to 5.5 digits.
I've been enjoying my 3055X-E for 4 months without any issues.
To make the improvement, check out this post:
patch the original SDM3055X-E_2.01.01.12.ADS with the following 16 bytes.
Then it's ready to flash in a SDM3045X. As always, do it at your own risk.
https://www.eevblog.com/forum/testgear/siglent-sdm3045x-enough-is-enough/msg3909188/#msg3909188 - more details are in that thread if needed, I think they also covered "unimproving" the device.
After modifying that specific version of the firmware, you can update to any unmodified SDM3055X-E firmware.
Language default will probably be in Chinese. To change it:
Click the Utility button, then System Config should be in English (2nd from right soft button if it isn't),
then Language should also be in English (1st soft button on left if it isn't).
The first language option should be English (but written in Chinese).
