Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
SCPI over LAN with HP Infinium 54820A
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: SCPI over LAN with HP Infinium 54820A (Read 2356 times)
lance666
Newbie
on:
October 01, 2013, 05:26:11 pm »
In the past I've used SCPI over LAN with Agilent scopes by connecting to ports 5024 and 5025. I have access to an old HP Infinium 54820A which has a LAN card. The scope connects to the network (I can see it from the router). But it doesn't respond on ports 5024 or 5025. Anyone know if these scopes can be controlled by SCPI over the LAN port, or is only GPIB supported? And if it should work over LAN any idea why it isn't listening on these ports? Is there some magic setting to enable it that I've not discovered?
Thanks.
Logged
free_electron
Super Contributor
Country:
Re: SCPI over LAN with HP Infinium 54820A
Reply #1 on:
October 01, 2013, 05:29:36 pm »
it depends on the firmware version. Lan control is there if the machine has 4.xx or later.
Agilent has a document describing what versions have the LAN.
Logged
lance666
Newbie
Reply #2 on:
October 01, 2013, 06:21:49 pm »
Ah, the scope says the software revision is A.03.50, so that presumably explains why it isn't responding. Is the firmware user-upgradable, and if so any idea where I'd find a more recent version (hopefully >= 4.xx)?
Thanks
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
