hello wraper,
I must say i don't use this nice mm enough to get use to all the feature and now i am the wiser re the REL button.
Problem it takes a few measurements to zero out the offset but after some practice i think i have it mastered.
Measuring low ohms however is still very problematic, as when the offset is set at zero ohms across the leads.
The next across leads measurement can often be as much as 0.5 ohms out again.
Which i guess is pretty much standard when trying to measure such a low resistance with a mm like this.
Many thanks imk
