I drew a schematic diagram,When you weld, you increase the welding temperature of the soldering iron,So it will cause discoloration of the PCB insulation layer,If the temperature is too high, it will cause two welding points to conduct and have resistance.
I'm referring to turning brown,To be precise, the PCB insulation layer is affected by temperature,Causing the previously insulated part to become conductive now
