Fluke 287 on min/max - just tested the battery on start - 3 times
first min reading was negative, under a volt -
not sure what that was about? - ghost voltage, as I set min/max prior to attaching leads to battery
second reading min was over 10 volts
third reading - saved
I'm thinking may be my 287 isn't so quick as other's 289? Ed to add Peak info from manual
