Hi All,
Just an update.
I was able to edit the OpenBuddai code and edited initialization sequence and the getSamples sequence as per the Logic140 code.
The getSamples sequences polls until receiveing a 0x21 before reading the buffer, as in Logic140 code and this seems to resolve the timeout issue. And, surprisingly, I was able to get something on the scope when probing the scope's signal. See attached below.Though I am unable to capture the square wave test source train properly.
May be, many of the other settings related to voltage /sampling/timebase settings too will need to be updated.I think we are not too far from getting this working.
@doctormord and or @papalukas, if we can have a quick skype call, we can figure out what is missing or needs to be tweaked and get it functioning properly.
Regards,
Shabbar
