The reason I tend to pop up like a bad stain on spectrum analyser threads is because I used to design the RF downconverter stages
I wish more would "pop up" here as you have.
I have ruled out the FSH3 from my original list, but have not ruled out it's replacement the FSH
4 other than the street price which probably is out of my range. I did look into the Hameg, but kinda ruled that out as I have in the past due to the lack of interest in the US with the what appears to be the very limited availability.
Add to that, it's AC only, The preamp is only 10db (most others are 17-20db), the preamp shuts off automatically above -10dBm & there appears not to have a marker table.
I did notice on the front of the scope, the R&S name with the Hameg name below it.
I also looked at the R&S FSL & the FSC, but other than the spec sheets, there seems to be very little elsewhere on either, just like the Hameg which gives me pause.
One worst thing about shopping for higher end test equipment like this is trying to get a actual bottom line price. "List" prices aren't even available unless you hunt and/or call for them. Prices for motor vehicles costing as much as many of these higher end machines are commonly available, why does it have to be different here?
