Author Topic: Measuring changing frequency and PWM as waveform(scope)  (Read 1210 times)
Offline loshampusTopic starter
« on: June 26, 2017, 04:39:25 pm »
Hi!
I am looking to buy a scope (usb) for automotive repair use. The problem is that new automotive airflow meters use changing frequency or Pulse width modulated output signal.
I know that Picoscope software can display changing frequency as its own waveform, are there any cheaper manufacturers that have that same function?(looking for under 300$ usb scope)
i am currently using an hantek 1008 and were unable to find this kind of function in the hantek software.
Thanks.
Online nctnico
Re: Measuring changing frequency and PWM as waveform(scope)
« Reply #1 on: June 26, 2017, 10:16:33 pm »
Look for input filtering. This can turn PWM into a 'regular' signal.
