@UniSoft
Is the hardware or software of the 6006P and 6012P so much different or why is it not planned?
I already have 4 models (6006, 6012, 6018, 6006P),
three of them are completely idle and just take up space.
I don’t want to invest in buying another one.
It is also time consuming.
Hello,
So after my post, I have found and install your custom firmware, and I find it great, so thank you!
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
I have read all the big "RD60xx Custom Firmware Reference.pdf" and have tried many settings.
But I have the same overshooting problem with this one too, like the one I have posted before.
After some searching, my thought is that it is probablly because the output is activated too fast.
Do you think you could add a menu for slowing down the rise of ouput with a timing setting ?
I have tried also the using of the green port with the GreenOutput option: it seems to be better, but randomly (I think the relay slows a little down the rise of the ouput).
Also: same overshoot behavior after a releasing a short of the red/black bananas.
Thank you !
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
Edit: I have posted the video I have made for their support on Youtube:
Edit2: Here is my 3 years-old DPS5005 in comparison (I have sent to the RD support).
It is a lot slower, softer start, have more noise, but not a single overshoot.
And I can not notice the slow start when I use it
