Author Topic: RuiDeng Riden RD6006 DC power supply  (Read 429950 times)
Offline bateau020
Re: RuiDeng Riden RD6006 DC power supply
« Reply #1250 on: May 02, 2024, 06:00:26 pm »
Is there anyway to use the Riden RD6006 flashed with the great Unisoft firmware with Sigrok? I would like to do power logging
https://sigrok.org/wiki/RDTech_RD_series
The following users thanked this post: myf, ghoes
Offline NutuElectronist
« Reply #1251 on: May 15, 2024, 06:46:25 am »
Hi .
I have big problem with my RD6018 .
My RD6018 dead completly STM32 have go in short circuit and now i buy new STM32 circuit and short circuit is gone.
But now i need firmware to install on STM32 please let me know how i can do that and from where i can take firmware.
Thank you and please help me.
Offline darkspr1te
  • Country: zm
« Reply #1252 on: May 15, 2024, 09:54:03 am »
if the boodloader code is the same for 6018 and 6012 then flash this file and it should work.
« Reply #1253 on: May 15, 2024, 02:02:24 pm »
Thank you for your help but i think not working.
I have change stm32 with another new one and i think no have bootloader .
I write your dump with STM32_ST_LINK_UTILITY is good ?
If i buy another device how i can back-up dump from STM32?
Thank you.
Offline darkspr1te
  • Country: zm
« Reply #1254 on: May 15, 2024, 03:22:42 pm »
The file I have provided includes the bootloader+firmware, it is from the rd6012 with stm32f103 mcu.
« Reply #1255 on: May 15, 2024, 04:39:18 pm »
In this cases i have more problems .
My processor is STM32F103RCT6 .
On the board have 25q32 and 24c04 i think one is flash and one is eeprom right ?
But i can write your dump with STM32_ST_LINK_UTILITY  ? or need another software ? :phew:
Thank you for your help.
Offline darkspr1te
  • Country: zm
« Reply #1256 on: May 15, 2024, 05:09:25 pm »
Yes, you can write the .bin file with st link or st prog (current st flash software) or openocd.
the 25q32 and 24c04 are used for storing settings and logging data i think.
It's been a while since i wrote code for this so am no sure.
darkspr1te
The following users thanked this post: NutuElectronist
« Reply #1257 on: May 17, 2024, 06:09:27 am »
Hello.
Problem now is 24c04 i cant read with programer i think is faulty.
If remove chip from board can see on display Bootloader V1.10 fIRMWARE VERSION : V-,-- .
If i put back chip on board pwer up but nothing on screen.
Can hepl me with binary from 24c04 ?
Thank you again for help. :)
Offline darkspr1te
  • Country: zm
« Reply #1258 on: May 17, 2024, 07:52:19 am »
If you are seeing bootloader but not seeing the application version or even booting into applicaition you should do a firmware upgrade and see if it goes into the main app. if you are unable to read the 24c04 in a external programmer i would replace with a blank one, the factory firmware will write default value to this chip if blank, but if the system cannot read/write to a chip it will hang at that point while it retries.
darkspr1te
« Reply #1259 on: May 19, 2024, 09:32:18 am »
Hi there.
Yes first i change 24c04 faulty with brand new one, before i read with programmer an i erase .
Same problem with 24c04 installed on board just pwer up but nothing show on screen no backlight no nothing.
When i take out memory display come on and show what i say you.
25Q32 is not faulty because i can read with programmer .
« Reply #1260 on: May 20, 2024, 04:32:53 pm »
Hi there.
I forgot to say , screen not working good .
Attash the photo.
Thank you.
Offline UniSoft
  • Country: kz
« Reply #1261 on: May 21, 2024, 12:37:13 am »
...new STM32...
...please let me know how i can do that and from where i can take firmware.
Best solution, is to contact with RD Support and ask them for the new pre-programmed MCU.
There is a some kind of copy-paste protection in code (based on unique id),
so even if you upload a full dump from another MCU, it will not work.
Also, all bootloaders are incompatible... so BL from 6012 will not work as 6018
There is no 24c04 (eeprom)! It is MB85RC04V (FRAM) used to store settings (also calibration constants).
25q32 is used to store logo only.
Keep pressed ENTER while power on, and you will see same string.
Nothing on display is because protection.
Screen working, but the bootloader what you've upload is the old version and doesn't know anything about that type of display.
« Last Edit: May 21, 2024, 02:53:47 am by UniSoft »
« Reply #1262 on: May 21, 2024, 05:56:04 am »
Hi UniSoft and thank you for your help.
In this cases is rubish i can do nothing .
I dont know if guy from Riden help me .
Thank you.
Offline bnae38
« Reply #1263 on: May 26, 2024, 03:12:40 am »
Hi bnae38,
I never got a direct response from you regarding this. Is it not possible?
So the rd6018 can see a difference in this small step in current with the custom code.
However, it wont register anything below 10mA current draw.
Perhaps I just didn't notice your question.
ADC in MCU is 12 bits (212 = 4096 steps).
Therefore: 20A / 4095 = ~0.005A (Physical resolution)
Thanks to oversampling, the resolution is slightly increased (but with a loss of accuracy).
Why minimum 10mA?
I made a software restriction (just in case), as the original firmware process the same (only 2 digits after the decimal point),
and it was calibrated without taking into account the 3rd digit after the decimal point.
I was worried that some devices could show not zero value without any load.
Hi Unisoft,
Would it be possible to add sub-10mA visibility as an option in firmware? Perhaps with a disclaimer on accuracy?
That would be awesome 😎
« Last Edit: May 26, 2024, 03:14:31 am by bnae38 »
Offline The Doktor
« Reply #1264 on: June 09, 2024, 09:27:15 pm »
Is there any chance of a replacement firmware for the RK6006?
Offline myf
« Reply #1265 on: June 10, 2024, 06:12:10 pm »
Hello,
I store my electronic equipment in a large crate (approx. 0.4x0.5x1m). Multimeters, relay usb interfaces, soldering equipment, etc. are in pouches or bags.
I now have a heavy rd6012 power supply with its mains supply. I don't know how to store it. It must be at the bottom of the crate because of its weight, but the front panel with its screen, buttons and usb socket are fragile, and I don't know how to protect it.
Do you have an idea for a bag or protection for the front? I haven't seen any pouches or boxes on aliexpress. Or how about making a cover to clip onto the front with a 3D printer?
F. from France and translated with DeepL.com (free version)
Offline bateau020
« Reply #1266 on: June 10, 2024, 07:19:04 pm »
The simplest is to take some rigid foam and cut out the forms. Do not use expanded polystyrene, as it will get everywhere and can provoke ESD problems. Best is to pack all material in electrostatic discharge (ESD) bags before using the foam.
FR: Le plus simple est de prendre de la mousse rigide et de découper les formes. N'utilisez pas de polystyrène expansé (les petites boules), car ça se met partout et peut provoquer des problèmes de décharge statique. Le mieux est d’emballer tout le matériel dans des sachets antistatiques avant d’utiliser la mousse.
« Last Edit: June 10, 2024, 07:28:27 pm by bateau020 »
Offline electr_peter
  • Country: lt
« Reply #1267 on: June 10, 2024, 07:27:37 pm »
Find photos of how RD6006 is packed in factory box, there is a foam piece that covers front panel and rotary encoder. Make a template a cut similar piece from pink ESD foam, that shoud protect LCD screen.
Offline ironcurtain
  • Country: aq
« Reply #1268 on: June 11, 2024, 09:19:33 pm »
Anyone tried quieting down their RD6006? (I got proper spooked by the noise in the scope before I realized it was the PSU, while diagnosing something)
"If you are going to fail, at least do so spectacularly."
Kurtz: [intercepted radio message] I watched a snail crawl along the edge of a straight razor. That's my dream; that's my nightmare. Crawling, slithering, along the edge of a straight razor... and surviving. -- Apocalypse Now (1979)
Offline Curious
« Reply #1269 on: June 22, 2024, 10:03:35 pm »
the voltage display reads high when charging batteries or powering loads at high current because of the voltage drop in the cables.
Would it be possible to add either an input for lead resistance, or a calibration routine to determine it (say for example shorting the leads and measuring voltage drop at 1A)?
Then the firmware could utilize this value to compute a correction to the voltage depending on load current.
Hence, a virtual 4-wire kelvin connection to the load with no hardware mods needed.
I doubt...
Such an idea has already been proposed, but it does not make sense due to the low resolution of the ADC and PWM.
But it can be done hardware, without any problem.
see attach...
instead of resistors better to use low resistance PTC.
Well, the disadvantage is that when the power wires are broken with Sense connected through these additional resistors, a large current will go, and they can burn, with PTC this risk is much less.
Hello,
I see that RD6006P (not RD6012P) has remote sense hardware leads, per user manual page 48 http://www.ruidengkeji.com/inst/RD6012P.pdf.  Anybody have experience with using the 4-wire on RD6006P?  Unfortunate that the switch is difficult to reach, and that the higher power RD6012P doesnt have the feature.
Offline sonpul
  • Country: ua
« Reply #1270 on: June 23, 2024, 08:50:07 am »
I didn't even suspect that such a function was present in the rd6006p. Thank you for bringing this to our attention. Older versions of 6006p do not have such a connector or function. :(
https://youtu.be/eoKe2-gCZxg?si=Sp4hqAAnpnHHCLEo
« Last Edit: June 23, 2024, 09:07:47 am by sonpul »
Offline img999
« Reply #1271 on: July 06, 2024, 11:06:40 pm »
Hey guys,
all calibration procedure is related to a 6006 therefore it isn't clear for me when I calibrating the RD6018 the higher amperage value is a fixed 3A value for every RD model from 6006 to 6030, or my assumption is that the 3A is the half of the RD6006's max. 6A output, therefore RD6018's value is 9A (which is the half of the RD6018's max. 18A output)?
Thank you for sheding light on this. :-)
« Last Edit: July 06, 2024, 11:09:48 pm by img999 »
Offline SpottedDick
  • Country: ie
« Reply #1272 on: July 30, 2024, 08:16:39 am »
Hi All,
Was there ever any work done on getting the OCP on the custom firmware to follow the voltage setting? I know it was proposed a few times and I check in every few months to see if it was done, but never seen anything.
Basically, I have a 400W supply that can do 8A at 48V, but can do 16A at 24V etc...
I'd love the OCP to automatically set the over-current protection per the selected voltage.
SD
Offline UniSoft
  • Country: kz
« Reply #1273 on: July 30, 2024, 10:57:57 am »
Hi All,
SD
You probably just want to limit the input power (to protect primary power supply from overload)?
For this there is an option in the menu:
Menu -> Settings -> Max Power   (This option also exists in the original firmware).
So, as your power supply is 8A at 48V (maximum power: 8A * 48V = 384W):
and since the efficiency (of RD module) is not 100%, then
384W * 95% = 384 * 95 / 100 = 364W  (95% is a recommended by developers)
Set the "Max Power" option to 364W, and you will no longer be able to overload the input power supply
(You simply cannot set the parameters at which the input power exceeds the specified limit).
Offline SpottedDick
  • Country: ie
« Reply #1274 on: July 30, 2024, 11:15:31 am »
Yeah, I've just been in playing with it and that actually works in my case, so I'm delighted now.
I should have realised this wasn't an issue ages ago! Thanks.
