...new STM32...
...please let me know how i can do that and from where i can take firmware.
Best solution, is to contact with RD Support and ask them for the new pre-programmed MCU.
There is a some kind of copy-paste protection in code (based on unique id),
so even if you upload a full dump from another MCU, it will not work.
Also, all bootloaders are incompatible... so BL from 6012 will not work as 6018
On the board have 25q32 and 24c04 i think one is flash and one is eeprom right ?
There is no 24c04 (eeprom)! It is MB85RC04V (FRAM) used to store settings (also calibration constants).
25q32 is used to store logo only.
Problem now is 24c04 i cant read with programer i think is faulty.
If remove chip from board can see on display Bootloader V1.10 fIRMWARE VERSION : V-,-- .
Keep pressed ENTER while power on, and you will see same string.
Nothing on display is because protection.
I forgot to say , screen not working good .
Screen working, but the bootloader what you've upload is the old version and doesn't know anything about that type of display.
