Some updates...
https://mega.nz/file/M0cGHDoY#E7KRDOtHHokceLAirPa9iSA4w1HHY4tzxaF9Rq9Q9SA
RD60062_V1.36.1c.bin
RD60065_V1.40.1c.bin
RD60121_V1.34.1c.bin
RD60181_V1.36.1c.bin
New options in "Quick Settings" (Shift + Down)
+ "GreenTerm=>Out" - If ENABLE then the GREEN terminal will work as an output over relay (NOTE! In this mode the battery detection is disabled, so no charger mode).
+ "UCP" - Under Current Protection. Disables the output if the current falls below the set value. (Working only in Power Supply mode, no affect in charger mode)
+ "UCP Trigger" - If enabled, the "UCP" option will be activated only after the current reaches the set value.
+ In option "External LED" added new item "VG/CY/OxP", what means: CV-Green, CC-Yellow, OxP (any protection Blinking RED)
* The "UCP" and "UCP Trigger" options are also available in the "--- Power Settings ---"
Is there a way to get the functionality to automatically turn the output off if the load gets disconnected (no current draw), I feel like I had that at one point but I can't get it messing with any settings
Take a look at the new options: "UCP" and "UCP Trigger"
Thank you for the updates
Hello Unisoft, is it possible to add an option that turns off the output of the rd6006 and shows a warning message or sound an alarm (buzzer), if the input voltage is below a certain user definable value? i use a 14s6p (58.8v) lithium battery as power source and would like to set the minimum input voltage of 46.2v. when the battery discharges below this value the RD6006 should turn off the output/Lock output to OFF and warns of low input voltage.
For example:
set_minimum_input_voltage = user definable (Off or 6-70v, where Off disables this function and the unit works as default, and 6-70v user definable minimum input voltage range)
conditions:
if input_voltage >= set_minimum_input_voltage then RD6006 Output Normal
if input_voltage < set_minimum_input_voltage then RD6006 turn off Output/Lock output to OFF and buzzer alarm or show message, protecting the input supply if it is a battery.
if set_minimum_input_voltage = Off then ignore this function and rd6006 will work as default
Thank you
