In that case, I'd like to make a couple suggestions for improved clarity:
Change "USB" to "Front Panel USB"
or "Front USB" (depending on the number of characters available)
what for?
there is only one single USB...
Exactly ... Its confusing as it looks like there is another USB somewhere, or there are two places on the same page to change the same option.
I do see that 'Front USB' could also be confusing for the same reasons - it implies a second USB.
Perhaps changing the description from "
USB" to "
Interface - USB", as it is independent from the others??
Change the option "USB" to "OFF"
From beginning it was OFF...
But other people ask me to change it to USB (if USB is enabled)...
May be just rename that options to
TTL Interface
TTL Baudrate
So call the other interface TTL? I like that it does have the other options listed. Getting Wifi to work with it set as TTL would be confusing too.
Since USB does have it's own 'OFF' option, it doesn't seem necessary to have it as an option in the 'Interface' menu item.
That brings me back to changing the "
Interface" to "
Interface -INT" or "
Interface - 2nd" or "
Interface Module" or "
Interface - PCB" or similar?? (Depending on characters available)
Kinda Related
- If WiFi is only available one one baud rate, could the baud rate menu item be automatically changed to that value and the option to change be greyed out?
Of course it's all your decision, I think I wasn't as clear as I should have been in the first message.
