Thanks for sharing. I'm using RD6006 with your custom firmware v1.32.12 without any problems so far. From the tests you have done, do you think it is worth upgrading to the "P" version? What is your opinion about it? I see it still has some ripple at certain conditions. I expected it to be a little more cleaner. Does your custom firmware work on this new version? thank you.
