Check out TestController: https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/ it supports the RD6006 & RD6012
@unisoft, is it possible to add pulse output feature to the supply? Shall be useful to experiment on charging battery. Example like having a pulse width of on duty incremental of 500mS, and independent off duty of 500mS incremental, with control of current limit, and set voltage. Whole charging duration can be taken care by the timer-off feature that you have already done.
static const uint32_t g_VScaleTable[16] = { // mV
50, 100, 250, 500, 1250, 2500, 3750, 5000, 7500, 10000, 12500, 25000, 37500, 50000, 62500, 75000
static const uint32_t g_IScaleTable[16] = { // mA
50, 100, 250, 500, 750, 1000, 1250, 1500, 2000, 2500, 3000, 5000, 7500, 10000, 15000, 20000
static const uint32_t g_WScaleTable[16] = { // mW
50, 100, 250, 500, 1000, 1250, 2500, 5000, 10000, 12500, 25000, 50000, 125000, 250000, 500000, 1250000
I believe, it's not only dangerous, but also not practical...
Can anyone tell me the specs of the external temp. sensor.
Which value NTC en wich curve.
I can measure the R value of course.
Is it: Ntc 5K 10K 15K 20K 50K 100K 1M
and is it curve 3950 or 3435 or 3470?
#define THERMISTORNOMINAL 10000 // resistance at 25 degrees C
#define TEMPERATURENOMINAL 25 // temp. for nominal resistance (almost always 25 C)
#define BCOEFFICIENT 3950 // The beta coefficient of the thermistor (usually 3000-4000)
Is it possible to set the same colors in the graph
for U, I and P as the colors which are choosen for
the numeric values.
I will not complain, but in the latest version
for RD6012, the AutoPowerOff,
after setting the time for it, does not shut down anymore.
Note:
AutoPowerOff - working only in inactive mode (when output is OFF!)
Press any button, rotate encoder, external communication (PC, App) restarts the timer...
@ Unisoft and all.
Played with new firmware 1.31.6f (latest release)
Looked at the new ORP function.
Looks nice, have not een specific function for that at this moment,
but interesting. Tested with electronic load DL24 wich has an function
voor Constant Resistance.
When I set ORP to 9 ohm and delay at 10 seconds (Vset = 15 volt)
Set load resistance to 9,1 ohm, start the load, works perfect.
Set load resistance to 8,9, RD6012 shuts down after 10 seconds, works perfect.
When I set load at 9,1 ohm, works OK, but when I turn down resistance to 8,9 ohm,
with load switched on, Riden shuts down immidiate, without delay.
Not a problem, I want just to let you know.
Edit:
One small problem I have seen. Power State doesn't work anymore. Always off when turned on.
Edit 2:
Turning off mains with RD6012 switched on, then switching on mains, unit stays off.
Turning off mains with RD6012 switched off, then switching on mains, unit powers up.
Looks like an inverse "last state" option, power state always set to Power on.
Unisoft -
@ Tasca
https://monitor.net.ru/forum/threads/651114/page-90
new BETA (k)
