@ Unisoft and all.
Played with new firmware 1.31.6f (latest release)
Looked at the new ORP function.
Looks nice, have not een specific function for that at this moment,
but interesting. Tested with electronic load DL24 wich has an function
voor Constant Resistance.
When I set ORP to 9 ohm and delay at 10 seconds (Vset = 15 volt)
Set load resistance to 9,1 ohm, start the load, works perfect.
Set load resistance to 8,9, RD6012 shuts down after 10 seconds, works perfect.
When I set load at 9,1 ohm, works OK, but when I turn down resistance to 8,9 ohm,
with load switched on, Riden shuts down immidiate, without delay.
Not a problem, I want just to let you know.
Edit:
One small problem I have seen. Power State doesn't work anymore. Always off when turned on.
Edit 2:
Turning off mains with RD6012 switched on, then switching on mains, unit stays off.
Turning off mains with RD6012 switched off, then switching on mains, unit powers up.
Looks like an inverse "last state" option, power state always set to Power on.
Unisoft -
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
