Hi there,
I spent a couple of hours testing the last firmware for RD6006 V1.32.11. (I did not test the earlier versions)
First of all, congratulations, great job!
Here is my review :
1. As for me, you could remove Layout 0, since Layout 1 does the same and it is user configurable.
(just my two cents
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
2. When Output voltage is set over 40V (with 1V hysteresis) the fan is forced ON, even with no load
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
3. Some french translations could be improved.
Could we use an xml language file to customize texts?
4. BTW, I also updated the PC software to version 1.0.0.8.
The previous version had an xml file for each language (not sure it did use it though). Version 1.0.0.8 doesn't include these files.
Does anybody know if there is a way to customize the texts?
5. The sequencial LED test at startup is funny,
but the sequence should
definitely NOT include the |ON/OFF| button because at power ON,
one might think that the output is briefly turned ON and OFF, which is not the case, but I get a heart attack each time!
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
6. Let me tell you that you really did a very nice job!
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
I love the added functions
- Color selection (allows to select 1 color for Volts, 1 for Amps etc...)
- Layout selection using < > keys,
- Alternate display on status line was really annoying, plus temperature reading in °C
and F didn't make any sense!
- Power button LED brightness in standby mode (the slow blinking was annoying)
- Option "Save Mult." is very handy.
- Option "Mem Hint" is handy too
- Battery charging cut off current setting is great!
Thanks for sharing your work.
Regards.
