The Wifi connection doesn't seem to be working for me... Is this a bug or am I doing something wrong?
To answer your question, at least I need to know what exactly you did, step by step.
In the meantime, I can only guess.
--- How to use WiFi ---
-- If WIFI still not configured
1. You need select WIFI interface in menu. exit menu (settings saved only after exit from menu)
2. Restart device (use Power button)
3. Now you will see red string: Server IP: ---.---.---.---
4. Run App (Note: both device must be in the same network)
5. In app click on sandwich, and in menu "Network distribution", it will wait for RD6006
6. After some time RD6006 will change the string to the yellow, which contains IP, and one more string "Connecting wifi...."
If this not happens, search problems with network. (this is infinite loop, firmware just wait for the response from WIFI module).
7. in App click Next, end enter password, click confirm
8. Done, this steps need to make only once
-- If WIFI already configured
Run App first (it is working as a server), then start RD6006.
